Question about Dryers
110 the fan will not come on, I have to start the blade by spinning it with my fingers
    Top Expert:
  • 11,147 Answers
Bearings may be dry try lubing the unit and start on high then go through the speeds usually solves most fan hard starts
Posted on Dec 20, 2016
    Top Expert:
  • Dryers Master
  • 33,342 Answers
The fan motor is defective.
Maytag mff2558kew
There could be a number of problems, you need to have your refridgerator topped up, or your elliment went, another solution, check to make sure that nothing is blocking the fan in your freezer
Apr 17, 2014 | Refrigerators
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
The fan on the 1999 Plymouth voyager is making noise
Spin the blades with your fingers while listening for the noise--either bad motor bearings or a warped blade causing interference with the blade guard. (It might even be some debris in the fan space) If you are tight for money, visit a nearby wrecking yard to replace whatever you find wrong. It's easiest to remove the shroud assembly to replace a motor or fan. Hope this helps!
Oct 08, 2010 | 1999 Plymouth Voyager
Fan very noisy
It is unusual for fans to become noisy buy with the power off you can check to see if it the fan has something trapped in it - in which case remove it. Also check to see if there is any blade damage. Check to make sure it is securely fastened and if not tighten the screws / bolts that secure it. Spin the blades with your finger to see if it makes any noise, wobbles or is difficult to move. If so then it may need replacing. Make sure the blades do not protrude out of the casing - if so push down on the centre of the blade to see if it will go back into position. The power to the fan may be unregulated so the fan may change speed and effectively pulse and therefore change pitch – check the supply voltage and ripple content. Other than that the fan may just need replacing.
Nov 13, 2009 | Sony PFM-42B2 42 in. Plasma HDTV
Condenser fan is not running. coils are hot and the compressor sounds like its working. the evaporator fan is working. The refrigerator is not as cold as it should be
Spin the fan by hand and see if that helps. The condensor fan is causing head pressure to rise and the compressor is fighting it. This in turn will affect the cooling effiviency.Vacuum the cobwebs and dirt that has accumulated and vacumm the fan motor yhrough the vent holes on its end opposit the blades. Spin the fan blades with a pencil to protect your fingers. If the fan still won't turn, it may need to be replaced Good Luck_Ned_
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
1995 honda accord ex auxiliary cooling fan not engaging
The accy fan you are refurring to is actually the a/c consensor fan.The only time that fan operates is with the cycling of the a/c system.Verify by turning a/c on ,fan should come on & off with a/c cycles..
Oct 17, 2009 | 1995 Honda Accord
Strong noise notebook, CPU gets hot 75-80C
The fan may be faulty, it may have stopped or spinning slow.
Check the fan and clean dust/lint off the fan blades and heatsink fins. Spin the fan blades with your finger to see if it spins freely.
If necessary replace the fan.
May 04, 2009 | HP Pavilion dv8230us Notebook
Samsung 1080i compatible tv 42 inch
This is very common with Samsung and is considered a overheating or lamp issue. cheapest fix before changing out the lamp is to unplug the unit after it has shut off its fans and open the back up and blow all the vents and circuit boards off with can of compressed air. Then remove the lamp to get to the larger fan that is behind the lamp, be carefull to not let the fans to spin when you hit it with the air because it will spin the fans faster than they are ment to spin, so gently place a finger on the blades just enough to keep the fan still and clean off any dust you see on the blades and area. Put everything together and give it a test run. If it stays on longer you know it was just to dusty to stay cool , if no change then try the lamp.
Sep 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Nov 18, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
