Question about LaCie Computers & Internet
I have a LaCie hard drive which is overfilled and won't read can I remove some data without format
    Top Expert:
  • LaCie Master
  • 78,015 Answers
Yes you can, just open the drive and start deleting data.
Posted on Dec 20, 2016
Setting up external storage without losing hard drive info
Likely the drive came formatted for a PC; also likely that the existing data is PC based.. Reformatting the drive for your Mac (a good thing to do) WILL erase the existing data, but you may not need it...
If you want to save it anyhow, just drag-and drop whatever's on the Lacie (before formatting) to your desktop (maybe in a new folder if you'd like).
Then format the LaCie for the Mac (with journaling is best) and once done, you can drag the stuff you put on the desktop back onto the hard drive.
Hope this helps
Nov 30, 2013 | Apple iMac Computers & Internet
Restore files
You can have the data removed by a file recovery business, it is costly. They remove the stoarge media and read it directly using special equipment. Unless the hard drive works (you can read it with your computer) that is your only choice
Dec 12, 2011 | LaCie Computers & Internet
I have Lacie Rikiki Go 500GB, when the first format I set it with Mac user. Now I want to use for both Mac/Window. Pls advise. Thanks
the easiest way to allow you to share data from the same partition between MAC and PC is to format your drive as MS-DOS (FAT 32) with Disk Utility, but you will be limited to files of 4GB or smaller.
Another way to do it is to format your drive as NTFS with Windows disk manager and to install an add on on your MAC that allows you to write to NTFS partitions (without add on, you will only be able to read NTFS partitions)
Jan 05, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
No pc manages to read the Lacie external hard drive, I receive a non-formatted message (whereas it contains data). Any ideas?
May be file system got corrupted.
Try to open it via disk management and see.
You can try to restore your data on it..
there are software like get data back for FAT and NTFS..
I may help you to get these if you need it
Jun 24, 2010 | LaCie (301144) 120 GB USB 2.0 Hard Drive
When I put my mac in sleep mode and restart it I get a message that says I have not put my lacie hard drive away right. How do you do that.
The message you are getting is refering to removing the Lacie before disconnecting it.
Just as you eject a drive before unplugging the cables to prevent corruption you must do the same before going to sleep as turning off the power to your USB ports(which happens in sleep mode) is no different than unplugging the drive without ejecting the drive when the computer is running.
If your Mac is set to go to sleep and save power when it is not in use then you should only plug your Lacie in when you are using it and should eject the Lacie before going to Sleep.
Failure to do so will eventually result in a loss of data.
If you have already lost data from a Mac formatted Lacie drive then you should refer to the below link for assistance in recovering your files, if not simply follow the above steps and you should not have any problems as a result of your Mac going to Sleep.
Hope this helps FixYa,
Feb 11, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Need to format without losing saved data
The trick to not losing saved data is to back it up to somewhere else, like an external hard drive.
Nov 07, 2009 | LaCie 160GB USB 2.0, 7200 RPM, 160GB...
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
'not formated'
That's because your Mac was using a file system called HFSX. Windows uses NTFS. They won't be able to talk to each other without some sort of emulation. Check out for a free/open source app that you can install on your Windows machine that will read the data on the Mac-formatted drive. If you are just trying to get the drive to work and don't care about the data, right click on it from Windows Explorer, select "Format", then make sure you set it to use the NTFS file system.
Aug 09, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie hadr drive problem
Data recovery software.
Check this link:
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Computers & Internet Logo
69 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
