Question about Avanti Refrigerators
Just got avanti wc3406. Set it up. Plugged it in. Panel has EE flashing. Was able to set degree choice and temp. But EE keeps flashing. Cant find anything in book to help
SOURCE: Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Posted on Jul 13, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
SOURCE: Avanti Wine cooler Model #
I had this issue and it had all to do with ventilation. If the fridge is in too tight of a space without any type of air space this will be the result. I was able to cut into the cabinet behind the fridge and put a 18" x 18" grate that allowed air to move. Problem solved!
Posted on Jul 22, 2009
  • 1218 Answers
SOURCE: new gallery series frigidaire side by side.
If it is new (under one year old) then it is under factory warranty, and is not your problem.
Contact your selling dealer and request a service call. There should be no charges to you. Please post back if we are not on the same page as to the age of the machine. Jack
Posted on Nov 01, 2009
  • 66 Answers
SOURCE: MY FRIGIDAIR REFRIGIRATOR, wont cool or freeze..
Is the compressor running, If so then I can only suggest that you have a loss of refrigerant. 1st Check that the compressor is running, If it is 2nd check that the condenser is not blocked and that if a fan is fitted, is it running. If none of these are working Check that the start relay is working, ( is there any electric getting to the compressor, If not check the thermo switch. If there is the klixon or the relay may be burn't out. change these first. if no joy after this get someone in to check to see if you have not/or loss any refrigerant. I suspect a loss of refrigerant ( leak ), get the leak repaired and recharged with gas.
Posted on May 17, 2010
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
My Cyberccool Wine Fridge started beeping a few weeks ago and the temperature keeps flashing between 0 and 13 degrees but keeps beeping. I unplugged it and have just plugged it back today. It has come...
There are several temperature controllers that has sensors that when the temperature has not gone down a degree for 5 or 10 mins. it will make an alarm to tell you there's something wrong. There are also some that if the temperature that has been set is never been reached and the compressor is not shutting off, it will make an alarm to tell you there's something wrong. Basically, in refrigeration, if the refrigerant is low, it takes time for it to reach the set temp. or it never reached at all. Have your refrigerant checked.
Dec 17, 2017 | Refrigerators
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
My oven is not keeping the set temp. I always have to set it higher to get the correct temp. saw somewhere you can change something with the control panel to correct but cannot find it now.
KA OVEN WON'T WORK PROPERLY IT IS LOCKED ON 26O DEGREES AND IT WON'T SET HIGHER. HOW DO I UNLOCK THE TEMP SO I DON,T GET AN ERROR NESSSAGE. WE HAVE DIGITAL PUSH PUT BOTTONS
Oct 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The Wine Cooler Won't cool, the internal thermostat reads 39 degrees, but the actual inside temp is close to 70 degrees. The unit is set at 59 degrees! Sometimes I can unplug it, the plug it back in and...
Order a new control board if it is working after you unplug it it's because the control board is being reset. You can contact the manufacturer and purchase a control board directly from them .
Feb 02, 2018 | Avanti WC5100BG Wine Cooler
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Refrigerators Logo
43 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
