Question about Magellan RoadMate 300 GPS Receiver
Magellan 300 bought 300 on ebay and used set up cds from another unit cant et authorization codes to put maps in
Re: magellan 300
Could anybody post those index file. I think these are the unlocking codes. Is it?
Posted on May 18, 2008
Re: magellan 300
Hi. For some reasons, my magellan 300 does not have any sounds. Anybody know how to solve this problem? Is there a reset button on this gps?
Posted on Dec 24, 2007
Re: magellan 300
You have to contact magellan. They will e-mail you an index file. You have to hook up your GPS to the computer. Then cut and paste the file onto the GPS hardirve.
Posted on Jan 21, 2008
Re: magellan 300
You must make sure that if you are trying to download into a sd card. you have to make sure it is one that is recognized by magellan
Posted on Dec 11, 2007
0 characters
3 Points
SD Card for magellan 300,Can I use any card on it? I've just got it as a gift without the card. Is there any website where to buy it?
The Magellan Roadmate 300 and 300R both require preloaded map data to be supplied from an SD card. You can't just pop any card into the slot and get it working. It requires a card of 2GB or less loaded with Magellan mapping software. Magellan provides nationwide maps and regional maps. The 300R was a regional unit while the 300 included a national basemap.
If you have a model 300, you can still use the highway basemap to get routing from city to city but you will not have detailed address routing at the residential street level unless you insert an SD card with Magellan software. If you have a 300R model, the unit will be useless without the Magellan software on an SD card.
Magellan doesn't seem to offer much software support for this unit any more and the maps are difficult to find.
Dec 04, 2009 | Magellan RoadMate 300 GPS Receiver
When I power up the roadmate 300 says there are not maps....the drive shows that they are there ? when I connected to computer with disk asked for authorization code.....would not let me enter one...called...
Unfortunately the authorization code comes from Magellan so there is no way for us as end users to bypass it. I would call back to Magellan and ask to speak to a supervisor or manager. Someone there has to be able to provide the authorization codes, tell them you have a very popular blog and plan to let everyone know just how horrible Magellan's customer service is unless they help you. It is ridiculous that they would be holding you hostage essentially like this. I wish I could provide you with the authorization codes but unfortunately it is tied to the unique identifier from your magellan unit, and the serial number of the map software, both things that Magellan can easily check, and then provide you with the code.
I would keep calling until someone gives it to you, that is simply not acceptable.
So sorry to be the bearer of bad news, but noone on here will be able to give you those codes, it is a manufacturer dependent thing.
Good luck, sometimes it just takes a little persistence, and like I said, make sure you are talking with at least a level one supervisor.
Jul 11, 2009 | Magellan RoadMate 300 GPS Receiver
Missing SD Map Card on Magellan Roadmate 1212
Unfortunately even if you do find a card it will not work with your unit because the cards have to be for that unit.If it is from another unit the codes will not allow it to work. The only option I know of is to purchase your map for that unit and put it on a sd card
May 09, 2009 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
Loading New Map
I don't know if this is much of a solution, but from what I understand from my extensive research on this product (I bought one online and have been trying to get updated maps), Magellan no longer supports this unit. I looked on their website to confirm, and on the "Scheduled Map Updates" list, the Magellan 300 has no further updates available. Apparently, this has been the case for the last few years.
Sep 27, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan Roadmate 760
Install a SD card that is not registered on Magellans website and register it and it will give you unlock codes to load maps to the sc card and wham it works, I did and it works,
Aug 28, 2008 | Magellan Roadmate 760 GPS Receiver
My new Magellan Roadmate 300
You have to have the two cds that come with the unit to download onto your computer. If you can find these then there is a sd slot on the bottom of the unit covered by a small rubber cap .The sd cards must be the ones that will work on a magallen .You can go to magallens internet site and get a list of the ones that will work.
Oct 27, 2007 | Magellan RoadMate 300 GPS Receiver
Magellan Roadmate 360 Manager Software Program, and Preloaded SD Card
Hi guyz I pretty much did the same thing!!! I bought this gps for my girlfriend for valentines from a friend and i was trying to restore it to its factory default and the only option i found was repair and i did an internal memory format like a ****! well everything seems to be fine but no audio at all! I've done lots of research and it seems to be that the only way to fix it is by restoring the sounds files but where can i get them? I MEAN magellan doesn't provide any support any more due to the unit is discontinued! I mean how messed up is that? AND why would they provide with such a horrible option? that's sad! Can anyone please please please help me? please I'm going crazy here! :(
Sep 30, 2007 | Magellan RoadMate 360 GPS Receiver
No maps found!!
Hi - I have the same model GPS but I've been unable to locate a copy of the CDs and I'd love to get a copy of them - would that be possible? My email address is
As far as re-installing he maps, here's what I've found. I think this might help:
Locate the files that are loaded on the computer.Magellan Roadmate Manager example: C:\Program Files\Magellan\Magellan RoadMate Manager NA\Map\Basemaps
Copy all files. Make sure your Roadmate is connected and click on Example E:/Removable Disk and paste them with other files. It takes a few seconds to 1 minute to transfer the 25.5 mb file so don't unplug it until it is finished.
Sep 29, 2007 | Magellan RoadMate 300 GPS Receiver
Magellan RoadMate 300 GPS Receiver Logo
586 people viewed this question
Top Magellan GPS Devices Experts
Roni Bartlett
Roni Bartlett
Level 1 Expert
Chris Hunt
Are you a Magellan GPS Device Expert? Answer questions, earn points and help others
