Question about Kodak Office Equipment & Supplies
Where is there a factory trained technician in Washington DC. area - need solenoid link replaced.
I have two 760H Kodak Projectors with same problem.
5 Suggested Answers
  • 1462 Answers
SOURCE: Replace coolent in refrigerator
refrigerant does not need to be replaced. only time needs gassing up is if there is a fault with the sealed system such as a leak etc. what is your actual problem that makes you ask the question. get back to me if you like
Posted on Jun 07, 2007
  • 1089 Answers
SOURCE: pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Posted on Jul 04, 2010
  • 412 Answers
SOURCE: Kodak 750H and 760H neither will advance carolsel without manual
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
Posted on Nov 04, 2010
  • 412 Answers
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
Posted on Nov 21, 2010
760h kodak 760h forward and reverse
I'm assuming you mean that the projector won't cycle forward or reverse??? If so, the problem is caused by a broken SOLENOID LINK. The LINK should be able to be purchased from: www.micro-tools.com, along with instructions for installation. For what it's worth: This is not an easy repair. Good Luck !! Jim
Jan 26, 2014 | Kodak Office Equipment & Supplies
Kodak 860 h doesn't drop a slide or moves forward-backward
Because of it's age, your projector needs either a solenoid link or a timing adjustment to the slide change mechanism. Either one should not be attempted documentation and training. I recommend Langie Audio-Video on Commercial Street in East Rochester, NY. They still has factory-trained technicians.
Oct 27, 2010 | Kodak Office Equipment & Supplies
My Kodak Carousel 760H projector will not advance or reverse using either the remote or using the "advance" or "reverse" buttons on the unit. I am able to turn the tray manually. Is...
The problem is a plastic "link" that connects a solenoid to the advance mechanism. It gets brittle with age & cracks, yeilding the problem you have. You need to have the "link" replaced.
May 12, 2010 | Office Equipment & Supplies
Mar 20, 2010 | Kodak Office Equipment & Supplies
Kodak 760H will not advance slides
If the projector neither advances or reverses, then most likely the problem is caused by the cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is plastic, and over time gets brittle & cracks, rendering the slide change mechanism non-functional.
If the projector cycles in Reverse and functions in Select, then chances are the projector just needs an adjustment of the cycle solenoid.
Either problem can be addressed by a factory-trained service dealer.
Jan 18, 2010 | Kodak Office Equipment & Supplies
I have a very old Kodak 760H slide projector. I
Based on your description & what I know about those projectors, I suspect the solenoid "link" has broken. The "link" connects the cycle solenoid with the slide change mechanism. Over time, this plastic "link" gets hard, brittle and cracks, rendering slide change non-functional. The good news is there are still parts around to fix your projector & get another 20 years out of it. You should contact a factory-trained repair dealer to affect the repairs. Good Luck !!
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
760H projector will not go fwd or rev either from
The problem you are experiencing is caused by a broken cycle solenoid "link". The "link" connects the solenoid plunger to the slide change mechanism. Over time, the "link" (made of plastic) gets brittle, cracks and the projector stops cycling. Parts are still available (www.micro-tools.com), but this requires an experienced hand and a service manual. Once done, your projector should be good for another 20 years !!
Jul 06, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel Projector 760 H, Carousel will not move
Given the age of your Carousel 760H, the most likely cause is a broken "Link". The "Link" connects the cycle solenoid plunger and the slide change mechanism. The "Link" is made of plastic and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair is best left to a factory trained technician with a service manual.
Apr 05, 2009 | Office Equipment & Supplies
60 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
