We got power can hear motor but when you pull out the cycle dial it seems seized we can't spin the drum only a little bit side to side that's it
  • Jeff welch Dec 22, 2016
    It was a sock some how stuck in the pump...we gotten all back together as Ithe was rapped around that gear in there so anyways took it out put back together and works like new ..paid 50 for both washer n dryer and think it worked out this time for me lol appreciate the come back and merry ho ho and all that good stuff
    Top Expert:
  • Washing Mach... Master
  • 76,846 Answers
The washer transmission has most likely failed.
Posted on Dec 20, 2016
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
robocop
  • 90 Answers
SOURCE: Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Posted on Jan 19, 2009
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
Maytag317
  • 1136 Answers
SOURCE: The drum on my maytag epic z washer will not spin.
Hi, The belt must have came off. Remove the access panel in the front and see if the belt broke. If the belt is off, see if there is an access panel in the rear that will help you get to the belt easier.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
Hotpoint BWD129 Spinning Difficulties
IF it sits and you can turn it later, the only thing that would cause that is something heating up and becoming seized. When it cools off it frees itself. I would check the bearings on the drum.
Mar 12, 2014 | Washing Machines
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
Sep 20, 2012 | Maytag SAV3710AWW Washer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
My ge front loader will not spin. the door is
My front load washer will not spin or the drum will not turn on the wash or spin cycle.
Dec 13, 2009 | GE WBVH6240F Front Load Washer
Kenmore spin cycle issues
Does it agitate and spin at the same time? the motor has a pump on one side and gear case on the other. if the gear case is seizing then the pump is lagging because the motor is loaded from a seizing gearcase and the gear case needs to be replaced.
Aug 24, 2008 | Kenmore 24032\24036 Top Load Washer
Indesit WD11
is the drum turning round. is it draining at end cycle ? if the motor is spinning is it slow at start turning left then right after a time or does it just spin when its on spin cycle ? can you hear a clicking sound when it about to move or hear a clicking sound and nothing moves ? if you hear a clicking but nothing is moving it could be the switch on the main board has worn out, it could even be the motor but if it does a spin it could just be the switch on the main board. they soldered in on the board you can replace them if you have soldering skills or would like to learn.
Jun 22, 2017 | Indesit W 123 Front Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
