Manual for a Russell hobbsRHTL140 top loader washing machine
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
My washing machine russell hobbs rh1042 gets half way in to a cycle then stops and lights start flashing what does this mean
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Oct 24, 2013 | Russell Hobbs RH1042 Frontload Washing...
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Manual for lg washing machine wtr854
LG has the manual for the WT-R854 on their site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R854.jsp . Click on the Support tab and then look on the right side of the page.
I hope this helps.
Jan 12, 2012 | Washing Machines
I am needing to know where i can get an english manual for a top loader zanussi zwx 5100 top loader washing machine
contact a place that sales washers and dryer they may be able to cross referance and get you a manual.
Aug 29, 2010 | Washing Machines
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
