Question about Danby Washing Machines
My Danby DWM99W is just dead.
I finished a load with no problem. next time I went to wash more clothes it will not start the water fill. no hummm from the motor. just dead like its not getting any power. The outlet is fine.
    Top Expert:
  • Danby Master
  • 79,865 Answers
Is the circuit breaker for the wall plug tripped?
Posted on Dec 20, 2016
Testimonial: "No, the outlet is fine. I tried my microwave and toaster on it and they all work fine."
  • 2 more comments
  • yadayada
    yadayada Dec 20, 2016
    Then the PCB control has failed most likely.
  • Anonymous Dec 21, 2016
    ok..thank you. i will order one and replace it.
  • yadayada
    yadayada Dec 21, 2016
    That is just a guess, you understand that?
    Yes, I will check the continuity all the way to the board first. I will check the fuses and the physical components.
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
The water level will not stop filling up to the level desired. Washer will not drain out and then I need to empty it with a cup.
Your water level sensor is likely faulty. Contact your retailer, or Danby directly, for a replacement and instructions on how to do so. Note, if this is in warranty, they may require you to bring it to a service center.
Aug 27, 2010 | Danby DWM99W Top Load Washer
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Jun 04, 2010 | Danby DWM99W Top Load Washer
Daby dwm99w drains and fills water at the same time.
The outlet of the drain hose must be higher than the highest level of water in the tub. Otherwise, it just siphons through.
Aug 01, 2009 | Danby DWM99W Top Load Washer
FILLS WITH WATER AND DOES NOT AGAITE
100% sure you need a new belt, or at least an adjustment to it.
Jun 20, 2009 | Danby DWM99W Top Load Washer
I have a new Danby washing machine but leaks from the springs area and several other areas. Will not fill with water and no wash cycle will engage. Seems to drain...spins well...but has an "intermittent...
you have a new washer so why not get the service agents out under warranty to fix the faulty machine
ask why there was water in a new machine as that indicates not new but second hand
May 25, 2017 | Danby DWM99W Top Load Washer
Won't wash
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
May 21, 2008 | Danby DWM99W Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
