Question about Intex Pool & Spa
How to fix error code E 95 intex pure spa hot tub
  • 1631 Answers
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Posted on Apr 11, 2015
  • 108 Answers
SOURCE: I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
Posted on Jun 05, 2015
  • 50061 Answers
SOURCE: Why are bubbles forming in my intex pure spa jet massage?
the air bubbler is switched on
there is a leak in the suction side of the pump that is sucking in air
Posted on Sep 14, 2015
davidspra65638
  • 8175 Answers
SOURCE: My intex pure spa wont turn on pump and has j1 code
bad pump
Posted on May 01, 2016
Do the heat and filter on an intex pure spa hit tub need to run continually together? I would like to put a timer on the filter.
read the manual but generally yes as if there is no flow then the heater element will over heat , boil and burn out
Mar 18, 2018 | Therapure Four Person Inflatable Round Hot...
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
chlorine
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
How do you fix error code E90 in my intex pure spa pump? The control panel chirps and will not heat the water.
This fault code is No water flow sensed.
possible bad pump?
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
Corporate Tel # 1-800-234-6839
http://slink.intexdevelopment.com/b2cmnl/B2CMNLServlet?instantiate=B2cMnldownloadApp&action=pub_mnl&filnam=250IO_A0_1411_EN.pdf
http://www.intexcorp.com/support
Mar 21, 2015 | Intex Pool & Spa
I have an "Intex Pure Spa" inflatable spa. It shut itself off. when I push restart it starts up then in about 10 sec an "E" comes up on the screen and it beeps. What can I do to reset and fix the err
Has your problem been resolved?
Please use 'Comment', and inform the forum here of your experience.
What did you do? Did Intex help?
If you are still dealing with this problem, let us know.
If so, and for anyone else with a problem ...
Support Intex
Jan 30, 2015 | Intex Pool & Spa
Help my intex pure spa ssp-20 has no water flow
Hi does any body else have had this experience Hot Tub Pure Spa SSP-20 LCD Screen thermostat numbers disappearing ie 3 will disappear or the 8 etc then they come back for a while then goes again, hot tub was bought back 30 July 2014. only used it roughly 4 months in total thought it might be because off the heat but to be honest we've not had it very hot here in the west and bearing in mind these come from America which is mega hot ours is still under warranty but cannot seem to get any help with regard to this can it be fixed at all if anyone can advise would be grateful.
Sep 28, 2013 | Intex Pool & Spa
Pool & Spa Logo
1,309 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
