I have a Heat Dragon Reedy Heat 50 RLP50. It won't stay ignited when I let go of the knob after 30 sec or longer.
  • Robert Nichols
    Robert Nichols Dec 21, 2016
    How do I fix and where are parts available?
    Top Expert:
  • Heating & Co... Master
  • 15,387 Answers
Will need to check and test thermocouple --valve unit --and that your hooked up correctly propane [lp] to a propane unit or natural gas to a natural gas valve unit --also check flame is contacting the thermocouple
Posted on Dec 21, 2016
3 Suggested Answers
  • 224 Answers
SOURCE: I have a Heat Dragon
Sounds like the thermocouple is bad. Pushing the knob bypasses the thermocouple and permits ignition once you let go after thirty seconds it is supposed to stay lit. This is common with heaters.
Posted on Dec 13, 2010
SOURCE: heat dragon rlp50 have to hold the knob in to keep
its your thermal couple thats bad simple fix. swlutz@yahoo.com
Posted on Dec 07, 2011
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
Pilot goes out when I try to turn the knob up
If the pilot stays on when you are holding it down (you are manually opening the gas valve) but won't stay lit when you let the knob go, then the thermocouple is bad. The pilot knob needs to be held down for 30 secs or so. The pilot flame has to heat the tip of the thermocouple long enough to for it to output a small electric signal (that holds the gas valve open). If you look at the pilot flame, you will see the tip of the thermocouple in the flame. That copper tube runs from the flame to the gas valve and is easy enough to replace. They sell them at most hardware stores. If you see a lot of ash buildup on the tip, you can turn the pilot off and clean the tip and try again.
Dec 26, 2013 | The Companion Group Kozy World Portable...
Model rlp50 50,000 propane heater fan will run, will light, but won't stay lite when you release button, fan still runs
i have the exact same heater with the exact same problem. tested the thermocouple seems to be fine, tested the relay, it seems to be fine, could it be the gas valve????
Jan 12, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a Heat Dragon (rlp50) and it won't stay lit unless the control knob is pushed in all the time.
Dec 12, 2010 | Reddy Heater-30-55,000 BTU Variable
My reddy 30 heater will not stay lit after starting I have held the switch down for longer than 30 sec but it just want stay lit
thats sounds like a thermocouple problem its located right by the pilote light assembly,,,rod shaped object
May 14, 2010 | Heating & Cooling
My reddy 30 heater will not stay lit after starting, I have held the switch down for longer than 30 sec, but it just want stay lit
The thermocouple is what tells the gas valve to supply or not supply gas. Several things can cause the thermocouple to malfuntion.
1. pilot light jet is clogged and will not allow the pilot light to reach and heat the thermocouple. Repair by cleaning the pilot light jet out.
2. corrosion on the thermocouple which will also not allow the flame from the pilot to heat the thermocouple properly. Repair by sanding the thermocouple lightly with sandpaper
3. Thermocouple is bad and needs replacement.
Mar 25, 2010 | Heating & Cooling
One year old heater
Try to hold the button down for 30 seconds at least before turning the knob to ON.
If you are doing this and it still goes out after you let up on the knob, then it may needs a new flame sensor.
Jan 14, 2009 | Reddy Heating & Cooling
No hot air
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
Jun 11, 2008 | Dryers
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
