Question about Epson Televison & Video
My Epson MovieMate 85HD will work just fine for about five minutes, then it will shutdown and the lights will all be red and blinking. Will a simple lamp replacement fix this issue?
It seems to be overheating. The lamp will work and project images, but only for a few minutes.
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
  • 1153 Answers
SOURCE: No video No audio, Red light blinking TZ50V51
Sounds like convergence area problem.
Posted on Mar 13, 2008
video-tek
  • 150 Answers
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
Posted on May 29, 2009
  • 668 Answers
SOURCE: Toshiba TP55G60 shuts down and red light blinks
Check the powersupply for loose solder conncetions. Especially in the protect circuit.
There is a white waffer looking IC that has been known for the pins to pop open from the
high frequency output of the power supply.
The Powersupply is on the right side and pretty easy to tell. Please use caution when
working on this set because the caps in the powersupply can hold a good charge. If you have any doubts about doing it yourself, call a professional and hopefully the pain in the pocket won't overcome the pain threshold.
Good Luck,
Skyassoc
Posted on Jun 17, 2009
ladywinn
  • 5138 Answers
SOURCE: rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Posted on Dec 30, 2009
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
I have an LG 65 inch TV. Owned it about a year and a half. While watching it the picture will go off for a second or two. It happens every few minutes. What is the problem?. The sound stays on.
make this test and fix it. God bless you
The Basics
Before we explore more complex tv troubleshooting techniques, we need to examine the basics. First, we need to verify the TV is securely plugged into a power outlet. Don't laugh, but failure to plug-in the TV is the number one reason reported why electronics do not work. Second, you need to verify the remote has fresh batteries. This can easily be overlooked. The remote can be working one minute and not working the next, so replace the batteries Finally, verify that all cables and connections are correctly and securely attached.
Lamp Problems
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Televison & Video
Red light blinking for lamp and temp
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 20, 2013 | Epson MOVIEMATE 60 PROJECTOR Projector...
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
Replaced lamp, but TV continues to shuts down a few minutes after starting. I replaced the lamp and it still has the same problem. What else can it be? After about 4 or 5 trys, the TV seems to work okay.
Tv have alots of clicking noises too to get tv turn on?The Ballast board is having problems.The Ballast board job it to ignite the projection lamp.
Feb 18, 2011 | Samsung HL-S5687W 56" HDTV
Where is the epson moviemate 55 color wheel
Its in the optical engine near the lens. Any service to the color wheel would be a job for an authorized service technician.
Good Luck
Aug 15, 2010 | Epson MovieMate 25 Multimedia Projector
Sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Apr 21, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
My r230 epson printer is not working.
my epson photo r230 red light ink and paper buttone blink off and on <not the same time>
Apr 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
Televison & Video Logo
119 people viewed this question
Top Epson Televison & Video Experts
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
