Question about Sport & Outdoor - Others
I have a Zupapa trampoline and need to know if using it in colder temperatures is bad for the trampoline.
How warm does it need to be to use the trampoline and not cause problems for the material it is made of?
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
What age is it safe for kids to be using a trampoline?
Trampolines are great fun for kids but you have to follow safety guidelines as a lot of kids get injured using them. Generally kids under the age of 6 should not be on a full trampoline. But read this article on the livestrong website which gives good details about kids and safety on trampolines. http://www.livestrong.com/article/200039-what-age-for-kids-to-use-a-trampoline/
Aug 20, 2012 | Sport & Outdoor - Others
Do I need a cover for my trampoline?
Trampoline covers are a really good investment. They protect from weather damage, frost, falling leaves etc if you use a trampoline cover you are less likely to have to replace the bouncing bed or padding on your trampoline, and they can get really expensive.
How will I know when the springs on my trampoline need to be replaced? How do I replace them?
The moment you notice some wear it is time to replace the springs. Replacing them is not too difficult, but is crucial for jumpers' safety. I found you a great 5-step guide that will take you through the steps of replacing the springs on your trampoline.
http://www.ehow.com/how_2265313_replace-trampoline-springs.html
Jul 30, 2012 | Sport & Outdoor - Others
My kids have been nagging me for months to buy a trampoline. There seems to be a wide variety of products available. How do I decide which one is best?
There are several factors to consider when buying a trampoline for home use. The first factor you need to contemplate is size. This depends on the size of space you have for the trampoline and how many people will be using it at a time. Next you will need to decide on a shape. Trampolines are available in a wide variety of shapes - circular, rectangular, octagonal, or square. But above all features that you may take into consideration, safety should be a top priority. You should purchase your trampoline from a reliable manufacturer.
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Trampoline net
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Apr 05, 2009 | Trampolines BQC1620
Choking
Hello, the reason the choke improves performance in the colder weather is, because an engine needs more fuel in the cold temp. It doesn't burn as easily as it does when the temperature is warm or after engine is warm.Please rate this answer. Thank you
Mar 04, 2009 | 1987 Nissan Pickup
Sport & Outdoor - Others Logo
95 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
