Question about Engel Refrigerators
Engel 40 litre fridge is connect to my 12 volt power fridge stopped running disconnect and then reconnect it fridge starts then stops and won't run
  • 66 Answers
SOURCE: 35 litre Engel. Not getting cold.
can you feel if the fan is blowing air
Posted on Jan 22, 2008
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
  • 107 Answers
SOURCE: WRT54G keeps disconnecting itself, requires
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Posted on Mar 05, 2010
  • 523 Answers
SOURCE: long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Posted on May 05, 2010
Battery in caravan was hot so hubby disconnected it the fridge has stopped working so we put it on gas it keeps cutting-out does fridge need battery to work
fridge needs 12 volts to run control board re connect and disconnect heater element for 12 volt section
Mar 22, 2018 | RVs
We have an engel eclipse. We had it hooked up to 12volt and the generator and now it won't work on 12 volt. Any ideas?
http://www.engelaustralia.com.au/products_details.asp?productid=21365
While the below is not an eclipse, it is suggestive.
The only requirement needed for running your "E" or "F" series Engel Fridge - Freezer (The later Models) on a 240 volt generator is to ensure the generator you are using is A.V.R. Automatic Voltage Regulated. Please refer to your generators user manual. If it is an older generator with A.V.R., it doesn't hurt to add an in line spike protector or surge arrestor.
Engel Website
Jun 06, 2017 | Electrical Supplies
What temp is the best to run my 40 litre engel for 240 piwer and solar ??
there is not BEST setting . it will be what keeps things frozen
Mar 03, 2016 | Engel Freezers
My gold engel fridge stops working when battery gets down to 9 volts...how do I stop this safety feature...I have duel battery system and would rather it run right down.
You have a nice refrig. But, the safety feature is there to protect the battery. A 12 volt battery should really never be brought down below 9.6 volts. The reason is the battery cannot sustain a lower voltage without damage to its ability to recharge. The cooler cant run on lower voltages as well so it shuts off. It is all based in the science of battery technology. So be happy it dows cut off or you would purchasing more expensive batteries. Take care of your cooler its a nice one.
Jan 28, 2015 | Engel Refrigerators
Thermocouple
Does it ever actually reach the temp set? It may just need cleaning and a service so it cuts out at the right temp.
Apr 01, 2014 | Engel Freezers
How much Power is Consumed by your Engel 12-Volt Refrigerator Freezer?
Refrigerator setting (minimum) and freezer setting (maximum - running continuously) the Engel 12-Volt Refrigerator Freezers use approximately 0.9 - 3.9 amps for the smaller units to 1.4 - 3.6 amps for the large 84 Quart MT80 unit. Basically your Engel 12-Volt Refrigerator Freezer uses less power than most 12-Volt coolers 1/2 their size. See our Engel Technical Chart for your particular 12-Volt Refrigerator Freezer.
Aug 12, 2010 | Bosch Refrigerators
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
35 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
