Question about Refrigerators
Power to fridge fridge starts then stops and won't run it has been running
4 Suggested Answers
marcus1917
  • 66 Answers
SOURCE: car stopped running won't start
Sorry about the late answer. Was in the outback (I live in Haiti).Did you check for power to the coil? This should be the first step. If power then check the distributor (the models we've here have electronic distributors with one coil).
Posted on Oct 31, 2011
  • 1010 Answers
SOURCE: Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Posted on Mar 26, 2013
  • 5687 Answers
SOURCE: Blinking Fridge Light and Both Fridge & Freezer Warming Up
I would say to contact Servall, a component source for all appliance repairs. They have a Web site and are helpful. You should also try the Web for any repair Manuals for your unit.
There are timers for the Defrost cycle. I am familiar with the old mechanical type, the blinking of the computer type is often in a Code which diagnoses the problem. You need the Manual to translate what the blinks mean.
Posted on Jul 10, 2014
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Jul 10, 2014 | Samsung Refrigerators
What will cause a damper between the freezer and fridge on a side by side to stop working?
Recheck the board wiring, and make sure the damper has power when the thermostat calls for cooling in the fridge. If there is power, it's the motor or its connection to the baffle plate. If no power, it's the board.
Apr 24, 2014 | Hotpoint Refrigerators
Mar 26, 2013 | Refrigerators
Motor is not running
chec the termostat, he start and stop the motor, also chec rhe start relay , is on the box connection of motor, if thoes are ok and it is power , motor is damaged..when frigorific agent is lost , the motor run without stop and no freeze
Nov 03, 2012 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Compressor won't engage-water was shut off and on to house when away-no symptoms before-
no you need a new ptc overload relay thats mounted on the compressor it aids in starting and running the compressor
May 12, 2012 | Kenmore Refrigerators
Car stopped running won't start
Oct 24, 2011 | 1987 Nissan Stanza
Stopped cooling. called repairman who blew dust and dog hair out from underneath fridge. started cooling right away. 4 days later stopped cooling again. we did more vacuuming underneath because there...
a normal vacuum won't get out most of the debris ,, if you can get your hands on a compressor,, use air to blast the coils out,, then it gets blown out correctly
Jul 15, 2011 | Refrigerators
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
