Question about Bosch Saws
Need directions on how to pull out the Armature of BOSCH CS20 and convert it to 220volts internally?
I'm from India, Have a Bosch CS20. I am hoping on converting a Bosch C20 120v to 220v. I need instructions on how to pull out the armature off the gear housing? Also has anyone tried the Bosch CS20 120v on 220voltage? I guess by rewinding the Field and armature I should be able to convert it for the inside.? Is anything more required? Thanks Anyone, someone, everyone. Stay blessed.
  • Bosch Master
  • 1,896 Answers
Buy a second hand step down trafo 230v to 120v to made it a sheaper project , its not worth for this kind of handpowertools to customize it.
On marketing technical reasons, there are no equivalent components for this model cs20 the armature is look a like a Makita armature some type of bosch tools are comparable with parts in several variations. but little differences on measurements.
Posted on Dec 30, 2016
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
http://www.ereplacementparts.com/bosch-cs20-0601674057-circular-saw-parts-c-128_1138_9632.html
Dec 20, 2016 | Bosch Saws
Bosch 4000 table saw tripped breaker. Went to turn saw back on and no power. I replaced the speed control board and still no power? I checked the switch and is fine. Any ideas?
Remove the cap on the end of the motor and remove the 2 carbon brushes. (Ensure the brushes move freely in the tubes and contact the armature)
Remove the 4 screws holding the motor housing to the frame and pull it straight off. Check the copper commutator on the armature and make sure it is not burnt.
22123698-wvjv2ek3boqiwefmtj30yfqx-1-0.jpg If armature and brushes look fine my guess is you have a bad field (very common problem in this tool) #1619PA5590
http://www.ereplacementparts.com/bosch-4000-0601476139-table-saw-parts-c-128_167_168.html
Dec 11, 2013 | Bosch Saws
How do you remove the blade guard on a bosch cs20?
counterclockwise in the same direction as the little arrow you show as the sawblade turns around. if you look at your handle look near that you will see on the metal part of the motor house a metal ,a 90 degrees bent metal bracket which protrudes, pust on this and turn slowly the sawblade then you feel on am short moment and push it as far as you can then its locking the blade , then you turn the bolt counterclockwise and The bracket itself bounces back.
Aug 25, 2013 | Bosch Saws
Bosch table saw model 4000. Brushes where sparking alot .
It sounds like the armature is gone, if you are lucky the field coil is ok. Pull the back of the motor off and have a look at the armature where the brushes run if it looks burned or really rough the armature is gone and must be repalced.
Jan 08, 2010 | Bosch Saws
Solution for Armature winding technique used in demolition machin
Maybe contact people from this factory to become some technical information about your question Possibly more likely than Bosch try it. succes https://www.alibaba.com/product-detail/1614011072-armature-suitable-for-BAK-GSH_60330652111.html
May 05, 2017 | Bosch Sds - Max Demolition Hammer
Bosch 4000 table saw disassembly
turn the motor housing slightly until you can put a screwdriver between the housing and diaphragm, pull on the one side and push with the driver and it will come apart, I just did one yesterday. To get the armature out of the fan bearing you will need a dead blow hammer to tap on the diaphragm while pulling on the armature. The bearing is held in place with 2 screws, hope this helps.
Aug 18, 2009 | Bosch 4000 - 07 Electric Table Saws
Bosch 11224 vsr no noise
Make sure your brushes are contacting the armature, sometimes they hang-up. But it sounds like the crossover has failed. Its the part that changes the tool from forward to reverse. You need P/N 1617200262.
Any Bosch service center should be able to supply you with this part.
Apr 17, 2009 | Bosch Drills
Lack of power
Check the brushes and armature if it isnt that abused you can get away with cleaning the armature and replacement of the brushes...
Jan 18, 2009 | Bosch Hammering
Saws Logo
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
