Question about Microsoft Windows Media Player
Wmp 11 full of static
When I play a cd and when I try to listen to internet radio on wmp 11 the static is terrible when I listen to music in library its fine. Dell had no solution.I am running vista 64 bit.
  • 3 Answers
Have you tried new speakers
Posted on Jul 21, 2009
SOURCE:
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
How do I clear my recently added folder in my
When you delete a folder from WMP library you will be prompted to confirm that action and given a choice to delete the Files within the folder only from the library or from the library and the computer.
Choose to delete only from the library and files will will not be deleted.
Sep 10, 2009 | Computers & Internet
"drm licence not available"
It looks like you may have WMP 11 installed. You must try rolling back to WMP 10 to try and solve your problem. Follow, very carefully, the instructions here.
Aug 27, 2009 | Philips GoGear HDD1830 MP3 Player
Wmp 11 on vista
right click on your cd rom drive. Click on properties, then, autoplay>Select Music cd from dropdown menu. then select "take no action" for disabling WMP popup , if you have another cd player software, choose it to make that popup when you insert cd.
Sorry to say, That wonf fix your WMP but the problem. And sorry, there is not enough info to help you on WMP fixing.
Thanks
and yes, please dont forget to Rate, if it works.
Apr 10, 2009 | Microsoft Windows Media Player
How doi get the files to go to my windos media player library?
GO TO THE FILE WERE YOUR E-MUSIC IS DOWN LOADED TO AND EACH SONG AND LAUNCH IT FROM THERE MAKE SURE YOUR WINDOWS MEDIA PLAYER IS SET AS YOUR DEFAULT PLAYER YOU CAN DO THAT BY RIGHT CLICKING ON EACH SONG AND CHECKING IT AFTER YOU LAUNCH THE SONG FROM THERE IT SHOULD PUT THAT SONG IN YOUR WMP LIBRARY AND ALSO USE WMP TO PLAY THE SONG YOU DONT HAVE TO PLAY THE FULL SONG JUST THE BEGINING OF IT,IF THAT DOES'NT WORK THEN CHECK YOUR WMP SETTING TO MAKE SURE THAT THE SONGS THAT YOU LAUNCH WITH WMP ARE AUTO ADDED TO YOUR LIBRARY
Mar 14, 2009 | Audio Players & Recorders
Help downloading onto computer
This is an easy process, just connect a commercial USB cable that is compatible with your device or the USB cable that came with it to ur computer. go to my computer and double click on the MP3 player drive icon. Navigate to the MP3 drive folder where ur music files are stored, launch windows media player( WMP 11 is AVAILABLE AT MICROSOFT.COM/DOWNLOADS) or if you already have windows media player 11, that's good. click on tools in WMP and select OPTIONS, click on LIBRARY and click on MONITOR FOLDERS. select ADD to add your MP3 player drive to the list of monitored folders, after you finish adding the MP3 player to the list, click on OK and windows will search the drive for music and video files and add them to your WMP Library.
Dec 14, 2008 | SanDisk Sansa Fuze MP3 Player
SONG LIBRARY
just copy all the songs from your RCA player not the playlist...
Jul 21, 2008 | RCA H100 MP3 Player
I HAVE WINDOWS MEDIA PLAYER VERSION 11. I AM DOWNLOADING MUSIC FROM LIMEWIRE. HOW DO I PUT THESE SONGS INTO MY WINDOWS MEDIA PLAYER VERSION 11 LIBRARY.?
1st - BE VERY careful using limewire - it is SO very virus laden, and embedded in pictures and music.
Answer to your question - open the music with WMP, and then when it is displayed use the option to add to library.
Jul 02, 2008 | Computers & Internet
Transfer music from ipod to m250
I'm assuming your iPod music is in iTunes. You can point Windows Media Player to the folder on your PC that iTunes stores music in. For those songs that are ripped from your CD collection, they will appear in WMP to be synced to your Sansa. That's the easy part.
Unfortunately, your music that you purchased from the iTunes store will not. There may be an easier way to do this, but this method will work. First, burn your iTunes purchased songs to a CD, then rip them back to your PC. Set WMP to also look in the folder that you rip to for music in addition to your iTunes folder. You can identify several in WMP so once you establish the library, you won't have to switch back and forth between your iTunes library and this new library. You will then see that music in WMP to be synced as well.
Again, unfortunately, the songs from the ripped library will not have the song, artist, year, genre, etc., but you can edit this information easily. Right click on each song that doesn't have good info, and choose the "Advanced Tag Editor" option from the menu. There are several tabs that will appear in the window, and you can put in as much or as little info as you'd like. You can use your iTunes library to get this information from.
It is a bit of a tedious process, but it works!
Good luck.
Jan 14, 2008 | SanDisk Sansa m250 MP3 Player
Microsoft Windows Media Player Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
