Question about Panasonic Lands Phones
KX-TG4031C how to stop the base from ringing even though the phone has ringer off
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
SOURCE: ringer
1. Press Menu button
2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
3. Press {2} two times
4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
5. Press multibutton {>}, then press on/off button
Thats it....
Have fun
Posted on Jun 24, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
safenude
  • 124 Answers
SOURCE: ringer off displayed on base
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Posted on Jan 28, 2009
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Posted on Oct 01, 2009
Please tell me how to turn the phone ringer back on! Right now it's off. My phone is a Panasonic KX-T7730. Somehow, while setting up my phone, I turned the ringers off & now my phone won't ring.
Hello Joyce Sia,
You have two ways to cut off ringing...
Look for a "DND" (do-not-disturb) control...
used for napping, studying or just plain
being left ALONE...
ELSE...
On the LEFT side of your base you should
also have a slide switch... a CRUDE volume
has three settings:
- big bell = High Volume
- small bell = Low Volume
- bell with an "X" over the top = OFF
Check these settings BEFORE you do a general power
and battery remove.. and begin All over AGAIN...
Ask com What Your Question
Sep 09, 2016 | Panasonic KX-T7730 Corded Phone
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
The ringer on the phone is off. So, when the phone is off the base unit, I cannot hear it ring. How do I turn the ringer on? KX-TG2730
Hi! Most phones have a double function for the "#" key. Press and hold this button "#" and the silent mode will turn off/on.
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 03, 2011 | Panasonic KX TG2730 Cordless Phone...
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
The ringer on one handset (KX-TG1034) does not work.
Try turning the ringer on in the menu...it might be a defective handset if that doesn't work.
Jun 01, 2009 | Lands Phones
The phon is not ring only the base is ring
look on both sides of the handset for a ringer on/off switch.
May 28, 2009 | Panasonic KX-TG5632 Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Jan 27, 2009 | Panasonic KX-TG5632 Phone
Ring tone changed tonight--it is too loud and awful.
The Ringer ID, Light Up ID, Picture ID and Custom Ringer settings cannot be assigned via the software, nor backed up, restored or transferred to another handset.
3. The USB connection cannot be plugged in while the phone is being charged - it is also physically impossible to do so. Kind of dumb given the USB connection sucks a lot of battery power.
4. In fact the USB should plug in to the base/charger so the phone is instantly connected (like a PDA) once docked, with two-way synchronisation. This is not as important though, as #2 above.
5. It is possible (as I learnt the hard way) to inadvertently wipe out the existing phone book and all its hard fed Ringer ID, Light Up ID, Picture ID and Custom Ringer settings merely by attempting to add new entries thru the software without first retrieving the existing entries from the phone. On the positive side, re-sending the same entries does not overwrite the already set up Ringer ID, Light Up ID, Picture ID and Custom Ringer settings.
Jan 20, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
