Question about Dishwashers
How do you adjust the tension on a dishwasher door and where is it located on essentials dishwasher model cid45b16
    Top Expert:
  • Dishwashers Master
  • 40,304 Answers
The springs usually are located on both sides of the tub outside.
Posted on Dec 20, 2016
How do I adjust the springs on the door of a Frigidaire dishwasher Model # FDB24?
Springs run down both sides of the dishwasher from the door hinge to the back leg area of the frame at the bottom leg area. You adjust the spring/door tension but moving the spring to different holes in the frame area. Going one direction in the holes will loosen the door, going the other direction will make the door tighter.
Mar 26, 2015 | Frigidaire Dishwashers
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Just below dish loading door you will see a panel. Remove screws (if applicable) to remove panel and you will find the door tension adjustment. Turn adjustment usually with a screw driver to the left to loosen or opposite lifting door opened and closed till you are happy with tension.
Jan 31, 2011 | LG LDF6920ST Stainless Steel 24 in....
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Door has become stiff in operation and does not move up and down smoothly. is there an adjustment?
Most of the time the dishwasher door hinges are located on the framing at the bottom of the unit behind the kick plate. There should be a spring on either side with a series of small holes in the bottom framing. Move this spring closer to the door for less tension, further away for greater tension.
Sep 10, 2009 | Dishwashers
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
