Ovens Logo
Peggy Shuster Posted on Dec 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a brand new Jennair oven, model jjw2430ds01 that has stuck/shorted key error enumeration 0x1 on it- what does this mean and how do I get it fixed?
Bill Boyd
Level 3:
Top Expert:
  • Ovens Master 53,816 Answers
  • Posted on Dec 20, 2016
Bill Boyd
Ovens Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948974
Points
172802
Brand new -- under warranty-- talk wit your service agent or get a warranty inspection done
Getting a message on my JennAir wall oven that says: F2E1: Stuck/Shorted Key. Error enumeration: 0x1. The product is experiencing a problem and cannot be used.
Jennair says the fix is easy. It is a 'stuck' key which is causing a 'short' which actually isn't, but permanently on, closed circuit, you will need to get under the keys and clean them with electrical switch cleaner. Or you buy a new button module and control board for 1,000 bucks, thank you for buying Jennair!
https://www.youtube.com/watch?v=sR7NConRaxE
F2 E1 - Product Help - JennAir
https://producthelp.jennair.com > ... > Starts with F2
Apr 27, 2021 - Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again. Verify ...
Aug 30, 2022 • Ovens
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
1helpful
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
About 1 hour into the self cleaning process the F7 error light came on and I meed to know how to get rid of it?
on maytag's the F7 means a function key is stuck or shorted. google your oven model's codes.
Jun 22, 2010 • Ovens
2helpful
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Oven Fault Codes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Oven Fault Codes
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 • Ovens
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
1helpful
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
