Question about Hardware & Accessories
Need manual for model 495 hose timer - Hardware & Accessories
Why is it that am i getting a 585 and a 495 errors simultaneously on two of the same machines
You did not post the model number. I assume it is a larger machine such as a MP9000. The SC495 is a clogged toner hose from the cup to the toner sub-hopper. If the toner system is not clogged it is a bad toner pump, or sometimes it is a bad toner sensor on the sub-hopper or the cup on top of the auger from the toner bank. If the hose is not clogged and there is toner to the top of the sub-hopper then it is one of the sensors. They are identical.
Aug 11, 2014 | Ricoh Office Equipment & Supplies
I need restriction code for my Nokia Xpressmusic-model 513 0c-2 type RM-495 CODE:0582928 IMEI:354223/03/319432/5 FCC ID:QTLRM-495 Thank you!
what is Country and Network it restricted now?
You can get the restriction code at here
Theunlockarena.com and Unlock it from Restriction lock.
Aug 07, 2011 | Nokia 5310 Cellular Phone
Need instruction manual for Orbit model 27133 sprinkler timer
Pretty sure this is what you're looking for:
http://www.orbitonline.com/lib/media/27133-24%20rA%20%284%291.pdf
Jul 29, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
I ned to reset the time on my orbit 2 station hose water timer and I lost my manuel. Please help.
To reset your timer, you'll need to replace the 3 AA batteries then press the reset button on the back of the housing.
If you'd like to refer to the manual, you can find the manual at orbitonline.com. Just click on the "manual and guides" link under the "Support" heading found on the left hand side of the home page. Enter the model number of your timer "62015" and click the quick search button. Your search will provide a link to the manual in up to 5 different languages in a pdf. file format. Click on the manual of your choice. Once the manual is downloaded (this will take a second or two if you have high speed) onto your computer you can print out the manual for future reference.
Hope this helps.
May 16, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
On the Noma timer Mod 49550/tm151p how can you tell when the switch is on
1) Noma is old Intermatic brand name used by companies today to brand their timer.
2) Noma is usually associated with Woods timers.
3) Woods numbers also frequently start with 495 and with TM.
For example Woods has 49588 49556 and 78 84 29 28 62 57 33 53 65 44 68 32 77, but 49550 does not show
4) It is likely that you have a Woods brand timer.
5) Add a comment with in-focus photograph of timer for possible identification
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
6) Open following link to possibly identify timer, and then add a comment saying which timer is same-similar to yours.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Read troubleshoot section to see if your answer is there:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Apr 22, 2011 | Hardware & Accessories
I am looking for a battery water timer that does not need pressure to operate. Just gravity. Any ideas?
Google search: 'battery operated timer' and 'battery operated hose end'
Smarthome shows the Orbit: and has manual:
http://www.smarthome.com/31035/Orbit-57860-Battery-Operated-Sprinkler-Timer-with-Inline-Valve/p.aspx
The manual says 'turn down water pressure.' It looks to me like this timer opens and closes the valve with or without water pressure.
Sounds like it would be perfect timer for above ground cistern where gravity cause water to flow when valve is opened.
Amazon shows battery operated hose end, but doesn't show manual:
Hose end timers are not going to have a pressure gauge.
http://www.amazon.com/Hose-End-Battery-Operated-Timer/dp/B0001O0DXO
Apr 18, 2011 | GARDENA Water Timer
Use old speakers with new computer
The speakers are most likely running at an optmal rate. i may be able to help you more if you can tell me about the difference in the sound from the old destop to the new laptop.
Jan 20, 2009 | Altec Lansing ACS 495 Computer Speakers
Hardware & Accessories Logo
54 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
