Question about Amcor NanoMax A12000E Portable Air Conditioner
A few days ago I moved my portable air conditioner unit from one room to another. (Amcor 12,000BTU, Cooling/heating unit) Prior to moving it, the air conditioner and compressor worked fine. The unit is about a year old, and has only been used a few months of the year thus far. After I moved the unit into my bedroom, and plugged it in, everthing kept working fine, (including the compressor) but a funny, slightly burnt plastic smell (or some other chemical smell) was blowing out of the unit aloong with the cold air. I turned the unit off for the rest of the night and next day. The following night I turned the unit on again, and the compressor kicked in with the same funny smell. After about 30 seconds, the machine gave a shudder, and the compressor stopped working.(the fan continued to work) The compressor has not come on again since. The fan works, and on the unit, the light indicator says the compressor is on, but it is not. No hot air is being discharged from the hose, the air coming out the fan is room temp. I went back and looked at the trouble shooting instructions. I looked at the outlet, to make sure it tested strong enough to support the power needed for the unit. And it did. I even tried it in another outlet. So I think I did something when I moved the unit. It says on the directions to drain water before moving unit. What happens if you don't? I wonder if there was water in it when I moved it. After I read that part in the instructions I went back to the unit to see if there was water in it. There was a little, but not a lot. I did not tilt the unit when I moved it, but I can imagine water might have sloshed around in there. What do you think is wrong with the unit? Is it something I can repair myself? Thank you in advance, Sheila
    Top Expert:
  • Amcor Master
  • 25,268 Answers
Perhaps the coolant gas has leaked out of the compressor.
Posted on Feb 27, 2017
shastalaker7
  • 1515 Answers
SOURCE: Compressor not turning on, no cold air
Hi, without the compressor running, you will only get room temp. air. You will be dealing with electrical trouble shooting to find why this compressor is not operating. If you do not have any electrical trouble shooting skills you would need to take it in to have it checked. There are several things you can check just by Looking, touching and so on. On a single phase compressor sealed pot, you will have a run cap, in your case it may be a dual cap one part to start the fan and the second part of the cap to start and run the compressor. I am telling you all of this so that maybe you and I can solve your problem. Just some things for you to look over being you are not an a/c Tech and have the equip. to check what would cause this.Turn off the power, and try and locate the run cap.If it is a dual cap it will be rather tall, 4 to 6" and oval with 3 terminals on top marked C, Hermetic, and Fan. Since you can't test it just look it over for any signs of oil leakage and bulging at the top and sides. If you do see this, it needs to be replaced. If it looks good it still may be open internally, but if you can excess the compressor, where the 3 wires enter, you should have a plastic cap to cover these wires. Try to remove it to see if maybe one of the wire connections have burned off, which will cause compressor not to operate. These are things that are checked in the field with meters and proper a/c tools, but you can look and find problems causing this. I wanted to give you a rather long explanation, as you can't always assume the run cap is bad unless you check it first. The compressor could also be shorted out or open windings.Without being on site, I can't check it. You if you can, look at the things I have told you, burned off connections, Leaking Run Cap or bulging at the top, it will be raised and distorted.Compressor terminals one may have burned off due to heat or loose connection. Please let me know what you are able to do, and get back to me.A little time spent exploring with my direction, may have you up and running with little or no cost. I'm just covering most all bases that we can under the circumstances.Sincerely,
Shastalaker7
Posted on Nov 19, 2009
  • 141 Answers
SOURCE: Fan works, cooling doesn't
check your condensor for dirt and any resets
Posted on Apr 08, 2010
  • 674 Answers
SOURCE: I Need HELP. I have two patients living with me.
First make sure the filters are clean. Then see if the compressor is running. If it isn't make sure its got power to it. If its got power then you can check the capacitor. Also check for any overloads that may need to be reset. Make sure all the fans are running. There should be at least 2. If everything is working then you may need to have the refrigerant charge checked. Does it have any trouble lights? The circuit board may have some LED's that blink to give a trouble code. Let me know what you find.
Posted on May 03, 2010
Testimonial: "THANK YOU. I've already checked most of them. I'll finish and let you know. Thank you for replying"
mastatech
  • 478 Answers
SOURCE: Air condition leakes water
you can get a small condensate pump, and run the hose to a drain like a sink or toilet, you may have to trick the switch if you have to put the pump inside, where the bucket would fit.
Posted on Jul 08, 2010
reyjoshua07
  • 1157 Answers
SOURCE: I purchased a AMCOR portable air conditioner Model
Hi path531,
Do you have any further inquiry about the system?
Hope it helps.
Thank you for using FixYa.
Posted on Mar 25, 2011
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
Why is my appartment getting cooler ???
An air conditioner really just moves heat from one place to another. Normally there is an inside unit and an outside unit, or in the case of a window unit, half is inside the room and half outside the window. In either case, it takes the heat from in the room and moves it outside. This portable unit apparently takes the heat from one room and dumps it into another. There is no magic heat elimination - it has to go somewhere.
Jul 01, 2014 | Simplicity 6,000 BTU Portable Air...
The cooling is not coming.I also want to know how to set it
Hi, I did some checking on this unit for you. To give you some direction to follow to what you are asking, call toll free Quality Matters Amcor.
866-725-9980
Not toll free 503-946-5869
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 24, 2011 | Amcor PLM-14000E Portable Air Conditioner
The thermostate now reads 112 degrees and will not go below 97 this causes the cooling unit to stay on at all times even though the true room temp is 71 degrees. What is wrong with this thing? It appears...
Hello,Locate and move the thremostat sensor(bulb) to a different location as it is near something on the unit that is 112*f.It needs to sample return/intake air temp.
Sep 18, 2010 | Amcor Portable Air Conditioner...
Unit vibrates violently
okay locate the screws on the bottom an the sides of the unit to open the system soon as the system is open ,try to locate the fan motor that supplies air to room an cools compressor off thats your problem with vibrations
May 16, 2010 | Amcor PCM 10000EH Portable Air Conditioner
Apr 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
May 07, 2009 | Amcor ALTL-12000E Portable Air Conditioner
Air exhaust hose gets extremely warm
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Jun 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Amcor NanoMax A12000E Portable Air Conditioner Logo
77 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
