Question about Dell Office Equipment & Supplies
I have a Dell 2335DN laser printer that produces a 'paper jam 0' error message but there is no paper jam. I open and close the paper tray multiple times until the paper actually prints. Suggestions?
I have to open and close the paper tray multiple times before the paper actually prints. I'm not sure what part, if any, needs to be replaced.
  • Dell Master
  • 825 Answers
I imagine this is a Lexmark model and if so then all you need to do is clean the pickup roller. that's the one that pulls the paper out of the tray. Use a damp cloth and put a little fairy liquid on it and clean the roller. Fairy liquid is a great degreaser and will remove all the oil from the rollers surface. it will then pickup first time provided the roller has not worn smooth.
Posted on Dec 20, 2016
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hello, I have a Dell 3130cn printer. IT is currently displaying the following message: Paper Jam 071-100 / Open Tray 1 and remove paper / Open and close the Front panel. I have done all of these things. I...
This error can also be caused by other problems, two of which are as follows.
1) The paper tray has a flap which opens when the MPF (Multi Purpose Feeder) is lowered. If this flap has been pushed out of one of its pivot points due to 'rough' handling of the paper tray, it can cause paper jams, and it can sometime cause the printer to 'think' it has a jam.
Just re-locate the flap properly, and make sure that it does open when you pull the MPF down.
I've seen this happen on a fe of these printers - keep your thumb OFF the flap of the paper tray when you open and close it to reload it with paper.
2) Paper quality can be a cause - seen this happen on this printer when a different paper was used - more likely with a printer that has done a lot of work and the pickup/transport rollers are starting to wear.
Replacement pickup and transport rollers are available quite cheaply on THAT well known internet auction site (and probably elsewhere to)
Apr 19, 2010 | Dell 3130cn Color Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Dec 20, 2009 | Dell 1320c Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
