What causes the thin twin washing machine to shake violently?
    Top Expert:
  • Washing Mach... Master
  • 48,421 Answers
Out of balance is the main reason for shaking machines
out of balance can be poor distribution of the wash or the tub and machine is not level
Posted on Dec 20, 2016
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
Washing machine shakes violently during spin
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
May 03, 2011 | KitchenAid Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
May 14, 2010 | Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Front loader shakes bad, is level, and on a concrete floor
You will have harmonic inbalance about 800 rpm on most front load machines, causing them to shake termporarily as it ramps up on the spin cycle. Be sure to check if the shipping bolts have been removed. This is the most common mistake most people make while installing front load machines. If you don't remove the shipping bolts, it will cause most machines to shake violently and can cause damage.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
PAV3300 ( Australia )
there is a plastic piece between the base and the gearbox assembly. it needs replacing as do the springs that go from the base to the washing drum. also make sure the floor is level
Feb 15, 2009 | Maytag Performa PAV3200
Violently shaking and noisy washing machine
I'm assuming you balanced this when you got it, right?
Mar 10, 2008 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
