Can't find the remote, vaguely remember not being able to operate the avr without the remote. Is there a work-around?
Remote doesn't operate receiver
ok to first check the obvious things. you are using the standard remote that came with the unit i can assume, and you've tried a different fresh set of batteries, and there is nothing blocking the receivers remote sensor or the remotes output sensor. If you have a smart phone there is an app for Denon AVR's that allow you to use your phone to control the unit assuming you also have a home network that the AVR is connected to.
If everything else works with the app you may just have a faulty remote, hard to test without trying it on another persons same model AVR
Mar 17, 2014 | Denon Deonon AVR-2113CI
Can i get a universal remote?
You can get a universal remote designed to work with home theater and other home stereo equipment.
Jun 06, 2012 | Denon AVR-4800 Receiver
HK avr 300 remote not working
Try another remote first, such as a universal one. If that doesn't work the system, the I/R unit inside is bad.
If you want to fix it yourself you might want to hunt down the service manual for it.
You can trace back from the I/R sensor to the PC board and see if there are any parts that can be replaced. You could even try changing the sensor itself.
Jan 04, 2018 | Harman Kardon AVR 300 Receiver
I have no remote and need to bring it out of
without remote u can not operate it properly go for a universal remote of reputed brands like One4All. its not costly also. U can program the remote by reading the manuals
Jul 05, 2009 | Denon AVR-600 Receiver
AM,NEED REMOTE CONTROLL DENON AVR-3802 HOW I,BUY?
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Mar 24, 2009 | Denon AVR-3802 Receiver
Denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Jan 27, 2009 | Denon AVR-2106 Receiver
Remote rc 1030
it must be your remote has been broken (just like my remote on tv) better to buy a new remote or buy a universal remote control.
thank you for using fixya
CHARCOIS
Oct 31, 2008 | Denon AVR-2807 Receiver
 Grubhead
Grubhead
