Question about GE Heating & Cooling
GE Zoneline 3100 PTAC UNIT no heat coming out just blowing cold air?
I have changed out the thermostat knob, and cleaned unit out for dust and debris everything else working and cycling just no heat blowing cold air. Any help with this problem thank you Alex
ACTECH
  • 80 Answers
SOURCE: I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Posted on Jan 14, 2008
  • 86 Answers
SOURCE: Zoneline 3100
check on / off switch.
wiring of unit
there is loss connection
Posted on Mar 16, 2008
SOURCE: Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Posted on Mar 30, 2008
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
  • 34 Answers
SOURCE: I have a zoneline ptac unit. The water keeps
They used to use a black rubber hose to run from the front to the back of the unit on the very bottom of the unit. You may also look for a styrofoam chute . Make sure the unit is sloped to the rear slightly.
Posted on Aug 18, 2009
Heating and air unit electrical manual
http://www.geappliances.com/products/introductions/zoneline/literature.htm
Aug 20, 2014 | GE Zoneline In Wall Ptac Unit Air...
Ihave 50 ge ptac units that only the middle of evap.is getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
Ptac unit
first check the capacitor this is usealy the most common problem
Aug 06, 2009 | GE Zoneline AZ55H07D Air Conditioner
GE PTAC AZ38H09DABM2 WENT DEAD..POWER OK
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at)airdistributors.com if you need further info.
Greg McNary
Air Distributors Company, Inc.
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
35 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Mack Baxter
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
