Question about Nikon D80 Digital Camera
I have a Nikon D80. A few months ago, the SD card would not stay in the slot, then for no reason it started working normally agan. Now it won't stay in again. It doesn't catch when you push it in, it just pops back out. Is there anything I can do or do I need to send it to Nikon for repair?
  • wolfe100 Jul 21, 2009
    I have had the camera several years and normally have no problem. I have tried to push the card in gently and also firmly. It still pops out either way.
  • 464 Answers
The sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Posted on Jul 21, 2009
It's probably a failure of the card holder. Happened on my D80. Unfortunately a repair involves sending it to Nikon to replace a big part of the camera. The UK cost is £190 (ca 300 USD) + VAT + labour
Posted on Feb 04, 2010
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Nikon d40xcamera...sd card won't click into slot
there is a lock on the side of some sd cards try checking if there is one.
Oct 30, 2011 | Nikon D40x Digital Camera
When i connect my d80 to my pc it freezes
You can try to a SD card adapter for the USB slot and download without the camera. The adapter is pretty cheap and sometimes comes with the SD Card.
The PC reads the camera as an external drive, make sure your PC and OS is up to date.
Aug 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 no picture number in LED & menu not working
Format the SD cards with the camera. You might have to do a software upgrade on the camera since the Kodak card files are different than Nikons.
Mar 29, 2017 | Nikon D80 Digital Camera with 18-135mm...
SD Card (2GB YES Make) Gives Formatting error
If you have a card reader or a printer with an SD card slot in it, try formatting the card or deleting all files on it using a PC. My laptop has a slot built-in I'm able to use. Check out your options. Try formatting it outside of your camera. I've heard of some card swapping between brands of cameras doing crazy stuff as you are experiencing.
Jan 07, 2009 | Kodak EasyShare C315 Digital Camera
D80 : Memory Card Fit
I know that an SD card could lose it's little lock if it is damaged, the worse place is in the slot where it would block another card from seating fully. (don't force it) Even in a padded case if the sd cards are sliding around loose the can get damaged or even get dirt, lint or fuzz in the "lock".  If this has happened don't probe around in there, if you do there may be further damage done, that one a camera repair shop might be able to do or you may have to send it to Nikon for repair.  Don't have the camera on or even the battery in if you can't resist trying and don't stick anything metallic in the slot.
randy320sgi
Oct 17, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80, memory card jammed
Can it be pushed into the slot any farther?
Feb 21, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera Logo
596 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
