Question about Coffee Makers & Espresso Machines
Open Question Espress Machine Minivivaldi water light is on but unit has water. It may stay on for a few minutes, but flicks off shortly after
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
skotkolr
  • 558 Answers
SOURCE: A OPEN MONITOR 2705-12S GOES OFF AFTER A FEW MINUTES
Capacitor failure is the common fail issue with LCD monitors these days they can be replaced.
Posted on Apr 05, 2009
  • 90 Answers
SOURCE: dashboard indicator flicking ie oil light and battery light
Hi !
Please check as to how old the oil is i.e. how many miles have you driven without changing the engine oil. The old oil looses its viscosity resulting in low oil pressure which ignites the lamp.
It will be advisable that in the next oil change you first Flush the engine with a cleaner and then only change the oil along with a new oil filter. This would clean the sump, oil pump and the censors resulting in a smoother drive.
Regards
Berry.
Posted on Feb 01, 2010
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
My Morphy Richards astral gas fridge will light just fine but will not stay lit after holding the red (disc) button even after several minutes. What is wrong? Thanks
Not familiar with this machine but found this
http://vintageshasta.proboards.com/thread/64
If you look / click at the high res versions of the pages it tells you; that you should hear a click of the safety valve after a short time lighting it. If the click is not heard, then the main gas safety valve will not open fully and the flame will go out.
This is a sure sign that the Thermostat .burner unit needs to be replaced.
See the manual pages and you;ll see what I mean.
From other postings I have seen the best place to get spares for these things is on Ebay.
Good Luck
Sep 16, 2014 | Morphy Richards 48280 FastBake Bread...
Front load frigidaire dryer does not heat and runs for a few minutes then shuts off and all the light flick off and on
Checkout the heating element. If it is open the electronics of machine may be programmed to turn it off and blink lights.
Nov 23, 2013 | Frigidaire FEQ1442ES Electric Dryer
Summit washer/dryer combo quit drying. Repairman came and replaced themafuse and thermastat kit. Shortly thereafter, the dryer cycle timer would indicate 10 minutes left and never clock down. The dryer...
summit washers are prone to board failures i would say that is where the fault lies . thermafuse fuse means it has been overheating. means it can damage other parts. thermostat would thing that has just worn out thermostat can go if the unit overheats. under line is an electrical fault. but like i've said it is a common fault with this make and others. the main boards can only handle around 50c in temp after that they start to over heat and cause problems. the faults started when they moved the main board from the bottom to the middle.
Oct 25, 2013 | Summit SPWD1470C 24 Inch Washer Dryer...
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
After pressing the 'coffee' button, a lot of noise but no coffee!!
this happens to me when i get air in the line that pulls the water out of the tank (i.e. you forgot to fill it up every now and then). you fill up the tank, wash you hands really well (don't want soap or germ in tank), partially put tank into machine and submerge the tube. then with your index finger flick the screen covered tip until no more air comes out. then, push the tank all the way back with the tube submerging all the way to the bottom. turn machine, push steamer butten, and turn knob to turn on steam for a few minutes to remove any remaining air in the tube. then, turn off machine, unpush the steamer (takes too long if machine on and unpush it for the espresso icon to light up so i just shut it off to reset it), turn on machine, wait for espresso icon to turn on, and then press button. voila. problem solved. i find the finger flicking step key b/c takes forever to purge a line full of air just using the steamer step.
May 29, 2010 | Saeco VIA Venezia
The monitor take a few minutes to start up, or the
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | Xerox XL-775D (Black) 17" LCD Monitor
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Jan 31, 2008 | Saeco Caffe Charisma Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
