Question about Miscellaneous
Open Question Minivivaldi water light is on but unit has water. It may stay on for a few minutes, but flicks off shortly after
3 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: A OPEN MONITOR 2705-12S GOES OFF AFTER A FEW MINUTES
Capacitor failure is the common fail issue with LCD monitors these days they can be replaced.
Posted on Apr 05, 2009
  • 90 Answers
SOURCE: dashboard indicator flicking ie oil light and battery light
Hi !
Please check as to how old the oil is i.e. how many miles have you driven without changing the engine oil. The old oil looses its viscosity resulting in low oil pressure which ignites the lamp.
It will be advisable that in the next oil change you first Flush the engine with a cleaner and then only change the oil along with a new oil filter. This would clean the sump, oil pump and the censors resulting in a smoother drive.
Regards
Berry.
Posted on Feb 01, 2010
Front load frigidaire dryer does not heat and runs for a few minutes then shuts off and all the light flick off and on
Checkout the heating element. If it is open the electronics of machine may be programmed to turn it off and blink lights.
Nov 23, 2013 | Frigidaire FEQ1442ES Electric Dryer
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
The lock on light wont go off. We can not start the dishwasher. We have tried holding the noheat option for several seconds and have turned off the circuit box for several minutes and neither one made...
That is the correct button to push to turn the control lock off. You can try to reset the control by removing power for two minutes. If the dishwasher is doing the same thing, most likely the touch pad has a shorted button or a bad connection on the unit control board. To check touch pad connection you will have to open the console. You will want to turn the power off to the dishwasher first.
Open the console.Once the console is open, remove and install the ribbon cable a few times. Now put the door back together and restore the power. If the dishwasher works, it was just a bad connection on the ribbon cable. If the console is doing the same thing, it could be a console or a unit control faulty. I recommend the console first.
Aug 03, 2010 | Kenmore Dishwashers
The monitor take a few minutes to start up, or the
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | Xerox XL-775D (Black) 17" LCD Monitor
Dashboard indicator flicking ie oil light and battery light
As the engine temp increases, oil returns to the sump (pump location) faster. You may just be low on oil. When its cold, the light is on at times...
Feb 01, 2010 | 1994 Toyota Corolla
Tray won't stay open
My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it.
Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
Jul 09, 2009 | Pioneer XV-HTD520 Multi-disc DVD Player
2002 Sable - Interior light stays on all the time when car is running. When the car is shut off the mirror safety light should only stay one for a short time but stay on for 15 minutes.
you have either the thumb wheel switch beside the headlamp switch is turned all the way up or a sticking door ajar switch.
Does the door ajar light in instrument cluster stay on?
If so then you can shoot some WD-40 into the latches on the side of the doors then open and close them firmly a few times and this will usually unstick them.
Apr 03, 2009 | 2002 Mercury Sable
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
