HP Pavilion dv6-1030us PC Notebook, just ordered the replcement screen mine destroyed on vacation. How do i remove the bezels all the videos I found on you tube do not show this model and I keep looking for "screws to take off
HP's have a snap on bezel with 2 screws on the bottom near the hinges. They are under a tab on the outsides of the hinges. You can remove the tabs with a small screwdriver. remove the screws and then the Bezel will come off so you can remove the 10 or so screws holding the screen in I watched how to on Youtube for mine when I broke it
it might be just your inverter its inside the lower part of the screen it plugs in and lights up the back light its cheap but you need to take apart the screen bezel and if you change inverter change the cable too these are not expensive parts its just doing it right and maybe not fix it but a cheaper way to isolate the problem
A) Graphics chipset B) Video Cable C) screen Inverter D) LCD screen
Let's diagnose, and find out.
A) Graphics chipset:
To start off with, the Pavilion dv5000 series of Notebook PC's; is NOT known to have a problem with the graphics chipset. The Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series; does.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop. The VGA port is on the Left side of the laptop, and located towards the rear.
This is a general example of a VGA connector (port), and VGA Cable,
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up. Turn the laptop on. By factory default settings, the display should show on the external VGA monitor. IF not:
There are at least 3 display options available; 1) Internal monitor of laptop ONLY 2) Internal monitor of laptop AND external VGA monitor 3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key. The F4 key is the Display Toggle-Over key.
Still no? Hold the Fn key down again, and tap once more on the F4 key.
No display on external VGA monitor, suggests a problem with the graphics chipset. (Most of the time it is a problem with the Mounting, of graphics chipset TO motherboard. If this proves to be your problem, state in a Comment )
Display on external VGA monitor means the problem is the Video Cable, or inside the Display Assembly. (screen Inverter or LCD screen)
B) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Switch Cover.
(Left side. Switch Cover is the plastic cover above the Keyboard, and below the LCD screen. Has the Power On Button, LED indicator lights, etc in it)
It then loops by the left Hinge, and goes up into the Display Assembly. There is a small separate wire that comes from the main Video Cable, and connects to one side of the screen Inverter. The main part of the Video Cable goes on, to connect to the back of the LCD screen.
Click on image to enlarge. The wide connector you see at the top/left, connects to the back of the LCD screen.
The wide connector at the bottom/right, connects to the motherboard. The single cable (Wire) coming off at the bottom, connects to one side of the screen Inverter.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pinched. This leads to it being pulled on, and may also lead to damage of the Video Cable. (Stretched/Broken wires)
Procedure is to Physically check the connections of the Video Cable. Visual inspection alone will NOT do. You need to physically see if you can plug the connection in tighter.
1) ALL power removed. Remove the AC adapter (Charger), and Battery. 2) Remove the Switch Cover.
[Switch Cover is just that. A Cover. I will give a link to a free Service Manual from HP Support, towards the bottom of this solution ]
Try to plug the Video Cable connection at motherboard, in tighter. Once done reinstall the Battery, and attach AC adapter. Plug AC adapter into power. Turn the laptop on.
Still no? Turn laptop off. (Hold down on Power On button) Remove ALL power again.
This time check the Video Cable connections at screen Inverter, and back of LCD screen.
The plastic frame in front of the LCD screen is the Display Bezel. Example,
Service Manual indicates to remove Display Assembly from laptop, in order to remove Display Bezel. IMHO this = NO. I think you can remove the Display Bezel, without having to remove the entire Display Assembly.
This video details removing the Display Assembly. Shows replacing the LCD screen.
What my concern is with removing the Display Bezel, is the integral Hinge Covers that are a part of it.
I believe the Display Assembly can be tilted far enough back, that the Display Bezel can be removed, and carefully ease the Hinge Covers out/off at the same time.
Why not just remove the Display Assembly? A whole lot less stuff to reconnect, after you have checked the LCD screen connection of the Video Cable, and screen Inverter connection.
After disconnecting the LCD screen from the Hinge Brackets, you just tilt the LCD screen forward, and check the Video Cable connection. Then slightly tilt the Display Cover back, so the LCD screen can rest against it, and reinstall power.
Connections are plugged in tighter, and this proves to Not be the problem, go on. (Don't forget to remove ALL power again)
The Screw Covers are made of synthetic rubber, or plastic. They are held in place by a type of rubber cement. I like to use a computer pick, (Much safer than a blade!), and lift up at the base of the Screw Cover.
I also like to GENTLY stick them to the Display Bezel for safekeeping. (They like to stick to the tool, your fingers, and it seems passing cars. "Oops, dropped one. Where'd it go? Hmmmm)
If you are careful with them you can reuse them. (Doesn't stick anymore? Apply a TINY dab of rubber cement to them, with a toothpick)
Screws removed, I suggest cut a piece of thick construction paper, that just fits the inside edges of the Display Bezel. Helps prevent scratching the LCD screen, from your fingernails, when you go to flex the Display Bezel, and remove it
The LCD screen is an Assembly of layers. They are held in the factory aligned position, by the metal Screen Frame which surrounds them.
There are screws that hold the Hinge Brackets TO the Screen Frame, and there are screws which when removed, will take the Screen Frame apart.
ONLY remove the necessary screws which hold the Hinge Brackets, TO the Screen Frame!
They are fairly easy to replace. There should be 6 rubber screw caps/bumpers around the bezel of the lcd. Remove the covers and the phillips screws underneith. Gently remove the front bezel. Take your time doing this, because they use some adhesive strips around the sides as well as some clips. If your not careful, you will crack the bezel. Once removed there should be about 3 screws on either side of the lcd holding it to the hinges. Remove these screws. Unplug the backlight from the inverter board at the bottom of the lcd and the main flex cable from the back of the unit. Installation is the reversal of disassembly. A new LCD can be purchased on ebay for around $110-150.
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
