Question about Fender 2 Stroke Full 49cc ATV # ATG-47B - Black/White
I just bought a 2 stroke 49 cc atv. Everything was working fine untill the engine just cut out. It started once or twice after several pulls of the cord but cut out soon after once again. PLEASE HELP, i only bought the thing 2 days ago.
    President:
  • 1,167 Answers
Hi mate are you mixing the bike with 2 stroke if not buy a mixing bottle with a ratio of 32/1 on ebay and buy 2 stroke and mix it up with petrol and oil if not the engine will seize also take the spark plug out and give it a clean with a wire brush and check the gap is ok and then put it in the plug cover and put the plug against the cylinder and turn the engine over and see if there is a descent spark if not replace the plug good luck
Posted on Jul 23, 2009
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Atv trouble shooting
I would eliminate the remote system. Cut all the wires going to it and connect the same color wires together. don't worry about the black wire.
Jul 20, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Does a 2008 zstar 49 cc mini atv have a normally open or a normally ignition switch?
The ignition switch is open until you turn it on. To hot wire one of these machines you simply cut the wires to the ignition and twist them together.
Jun 14, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
2 stroke 49cc carb settings
It is known as a bench setting that you need to know I believe. What you do is turn the screw all the way in and then back it out 1 and 1/4 turns. that is the starting point, you may need to back it out a 1/4 turn to get it to run better. Essentially you work in 1/4 turn increments.
Jun 01, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Trying to start mini quadard 49 cc model atv-2
Try turning the carb set screw all the way in and back out 1 1/4 turns. If you need more... do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO OIL MIXTURE
the mixture ratio is 50 parts gas to 1 part oil. Use only a good quailty stroke oil, never use motor oil
Nov 01, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
Hi,i own a dinli t-rex dl-601 100cc atv quad bike and i recently changed the v-belt,cleaned the carb,wahed filters,drained and changed engine oil,drained and changed petrol,drained and changed 2 stroke,...
I think you might want to change catagories, I found this under Bicycles. Also, I was curious as to how you can list it as a Quad Bike . . . Bike is a short term for Bicycle, Bi meaning 2 as in 2 wheels.
Nov 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a 50 cc kazuma atv i know the upper screw is the idle and the lower is the air/fuel mixture, what should the air/fuel mixture be set at, for example, 1 and a half out?
The easiest way to adjust the air fuel is using a RPM capable multimeter. But, in a pinch, a good ear will do just fine. Adjust the screw inward until the rpms drop. Turn it VERY slowly until the rpms return upward. Once you finish, just work the screw back and forth to get it to the point the rpms change (however this is not necessary). Congradulations. You're finished.
Sep 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Fender 2 Stroke Full  49cc ATV  # ATG-47B - Black/White Logo
377 people viewed this question
Top Fender Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Fender Cycling Expert? Answer questions, earn points and help others
