Question about Waupaca Elevators RESIDENTIAL ELEVATOR
My Waupaca elevator makes a moaning sound when ascending. Normal sounds when descending.The wheels have been lubricated by a technician, but the sounds continue.
Waupaca 3 stop elevator. Power went out. Stuck between floors. How reset elevator to get to proper floors?
There should be an escape hatch above your head on the ceiling panel. Try that but be careful. If not, pick up that phone next to the floor numbers and call the fire department.
Dec 28, 2016 | Miscellaneous
Why is the steering making a moaning sound on 1991 volkswagen westfalia ?
Groaning in the column itself could be the column bearings, or perhaps the horn contacts, although they make more of a scraping sound. A little lube sprayed between the steering wheel and column may help that. If you're referring to noise in the steering itself, sometimes the front upper control arm bushings groan when they're worn out. Or power steering fluid loss due to leakage from rotted power steering lines under the van. Trying to address all that I can think of, but your question is rather vague.
Sep 16, 2014 | Volkswagen Cars & Trucks
Moaning sound from front drivers side
sound like wheel bearing if car in motion.moaning while vechicle sitting still could be power steering pump or water pump bearing going bad.alternator with bad bearing cause moaning noise.
Dec 28, 2012 | 2005 GMC Envoy Xl
Squeaking/Moaning noise coming from passenger front wheel
Wow that sounds like a wheel bearing about ready to be replaced. Have a service tech check your bearings.
May 17, 2010 | 1995 Lincoln Continental
Sound in my laptop keep descending
Sometimes Flash player interferes with the sound volume. (ascending and descending back and forth)
Uninstall flash player> reinstall
Apr 27, 2010 | HP Compaq Presario V3000T Notebook
Hi richard_hutc,
It would appear that you have an issue with the finisher/sorter on the side of the machine.
Specifically, C-1183 means the elevator motor hasn't ascended or descended correctly.
Open and close the finisher and look for any paper jams in this area.
Good luck
Jan 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Autofilter ceases to work on large Excel 2003 spreadsheet
Sounds like there is a gap between the filter heading and the column data. That's the only time I've seen suggested data missing from the drop-down.
Jun 16, 2009 | Microsoft Computers & Internet
My 7222 copier will not start it is showing f-77-2
M7 (Elevator motor) drive abnormality
• While the elevate tray is going
up, the PWB-F (Elevate tray
top face sensor) is not turned
OFF in the specified period of
time after the M7 is turned
down, the M7 is locked.
• The S2 (Elevate tray upper
limit switch) or the S3 (Elevate
tray lower limit switch) is
turned ON in the specified
period of time after the elevate
tray starts to drive.
The main
body stops
and the RL1
(Main) turn
M7 (Elevator motor)
PWB-A (Control board)
PWB-F (Elevate tray top face
S2 (Elevate tray upper limit switch)
S3 (Elevate tray lower limit switch)
FS-114 F77-2 M11-FN (Elevator motor) drive
• During tray ascending, PC14-
FN (Top face detection sensor)
does not ON after specified
time from M11-FN ON.
• During tray descending, it
does not reach the target
position within specified time.
• During tray descending, M11-
FN is locked.
PWB-A FN (Control board)
PC15-FN (Top face detection
Feb 23, 2009 | Konica Minolta Office Equipment & Supplies
51 people viewed this question
Top Waupaca Elevators Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Waupaca Elevators Toy Expert? Answer questions, earn points and help others
