I have the same problem with an Electralog heater VAC 120, Model 6901050700, as another person, same model number. Flame works, blower works, starts out fine but then blows cold air. Is it fixable?
  • 41 Answers
SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
SOURCE: Frigidaire furnace model # FG6RA 096C 16B
Check your intake pipe for obstruction.
Posted on Mar 18, 2008
mrgrzz
  • 88 Answers
SOURCE: furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
  • 24 Answers
SOURCE: Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Posted on Sep 30, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
Laars LX Heater not starting
blower gets 120 vac. ensure proper voltage to blower to start
Jun 20, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
On my electralog heater, after about 5 minutes running the heat stops,fan is still running. Adjusting thermostat makes no change
From what you have described. it sound like the heating element is overheat and the automatic over heating sensor is shut it down. One of the primary reason these heaters overheat is that the become clogged with dust, lint & pet hair. Cleaning the heating element. may solve your problem. A vacuum cleaner (especially a Shop Vac) that has a hose, a brush attachment and a crevice tool, works well well in cleaning the heating element. Be sure the unit is OFF and unplugged, before attempting any cleaning.
Hope this helps you solve the problem.
May 19, 2011 | Dimplex Compact Electric Flame Stove...
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
Flame on electralog stove not working stove is still working
Rich's answer works for the heater problem, but not the light. My unit's heater quit working and I noticed the vents were clogged with dust. I vaccumed the front and back vents out with the unit unplugged and this fixed that problem. But the light/fire burn out is a different problem. I suspect it is burnt out bulbs, as I have had this unit for multiple years.
Sep 11, 2010 | Dimplex Compact Electric Flame Stove...
Wall heater not running. The pilot is lit but will not turn on.
With the pilot light lit, and if this is a older valve (no electronic ignition) then make sure the valve is turned to on (knob on valve.).
If knob is on, or system uses electronic ignition, then make sure the thermostat is calling for heat. Also make sure if the unit is 120 VAC powered, that power is on.
If electronic ignition, then the flame sensing circuit has failed.
Reply specific make and model number for more information.
Jan 16, 2009 | Heating & Cooling
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Need switch fort Presto Quartz Heater
Hello
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
