Question about RCA F27442 27" TV
I have a 27in RCA TV that has sound but the sound is complete interference or the old "snow" sound, not cable or satellite. Picture is perfect.
2 Suggested Answers
  • 458 Answers
SOURCE: "snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Posted on Aug 24, 2009
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
The picture on my HD tv is pictulating - I have a sky HD box. Some of the channels are perfect, some have a small bit of interference in the picture and some are unwatchable with a lot of crackling in the...
It is not the tv,but weak signal strength thru thru your satellite or cable box. Please call them to rectify this and you will not need service on the tv itself
Jun 15, 2010 | Televison & Video
Aug 24, 2009 | RCA F27442 27" TV
Perfect sound, no picture - RCA F32649
if you know how to solder ,re solder your tv, but before doing that replace or used other RCA cord
Aug 09, 2008 | RCA F32649 32" TV
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, however there is sound
Is this set hooked to cable? Is there a cable or satellite box? When you press the menu button, do you see the menu on screen? Do you see anything on the screen, such as snow, or is it completely black? If the signal is OK and the TV has no picture at all, the red LED on the front of the set should be flashing a certain number of times. If the LED is flashing, the computer has detected a problem in the set and shut the picture off. If this is the case, there is no way for you to bring the picture back by pressing buttons. The number of times the LED flashes is the computer's way of displaying exactly why there is no picture. The set should then be serviced by a qualified tech familiar with Sony TV's. If the LED is not flashing and the menu comes up on screen, check your signal source. If you are using a cable or satellite box, that box could be bad, and if you are using RCA jacks, the yellow (video) wire could be bad or pulled out.
Aug 20, 2007 | Sony KV-32XBR250 TV
27in RCA
have a tech repair your tv the power supply is deffected.good luck.
May 14, 2007 | RCA 27V530T 27" TV
RCA F27442 27" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
