Replacing my blower motorThere are only 2 wires on the motor. The furnace has a three prong plug. I need to know which two I need to put the wire into1 is the blower receptacle2 is Blue and3 is black
    Master:
  • 946 Answers
Take it back and get the right motor for that model. don-ohio (:^)
Posted on Dec 23, 2016
I am getting one light flash indicator limited circuit issues. The furnace fires and heats up but blower does not come on
Remove the blower motor, With the furnace circure breaker off!!!!!!!!!!
Put a universal 115 v plug on the two wires and hold it on the floor and plug ER in. It's a 115 motor, look at specs to make sure. If she don't , check wholesale house to get a motor. If not that, motor capacitor, then contact switch if capacitor don't do it. Be very safe!!!!!!! . The capacitor will need to be discharged and if checking it, do NOT
Touch both post. Discharge it before disconnecting it by turning all power to furnace off, taking a screw driver and putting it across both terminals. It will arc. Do that a couple three times to get rid of stored electricity. If it does arc with a little snap and spark, it's good.
BE SAFE. Hope that helps.
Jan 21, 2015 | Frigidaire PTAC Electric Heat 9000 BTUs...
I have a 1 horsepower variable speed blower motor for a Ruud furnace with plug-in power source and plug-in low voltage signal input plugs. I can't find the capacitor and want to know if I can direct-wire...
No you cant. You have a module motor so there is no capacitor. If the motor is new it may not be programmed. If it is a old motor replace it.
Sep 07, 2014 | Heating & Cooling
Replace blower motor resistor on 2002 Ford Sports track
On top of the blower motor where the electric wires are, you should see a plug end! unplug that wire plug, and you will have 2 smaall 1/4 inch screws ( 1 on each side of the prongs)! remove the 2 screws, and then remove that plate (the resistors will be on the inside of that plate.
May 17, 2014 | 2002 Ford Explorer Sport Trac
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
I have only low speed on the blower motor for heat The three wires connecting to the blower motor 1] red 12volts 2] think it a blk/yellow 2 volts 3] black ground i put 12 volts to wire 2 and the...
on the housing under the hood where your heater core and AC plumbing is there is a plug in rheostat that you need to remove and replace-take it off with the two screws that hold it and take it to a napa and they will sell you the replacement for about $20. Good Luck!
Oct 21, 2011 | 1994 Cadillac Seville
I disconnected the capacitor on my Westinghouse HVAC unit. I took pics to help me put the replacement on and my pics don't show exactly which prongs the wires hook to. I know the blue wire goes on...
You are talking about a three post capacitor. One post may have 2 or 3 prongs, but it is still the same post and it doesn't matter which prong you put it on as long as your are on the right post. I am going to try and send you a video of a three post capacitor hoping it will help you. One post is for the "fan" whiich, by what you are telling me is the blue wire. "fan" will be marked right on the top of the capacitor next to the post. Sounds like the Red is "herm" which is a compressor wire. Orange and Yellow are the "C" wires. One wire will go to the fan and one will go to the compressor.
Again,, It doesn't matter which spade or "prong" you are putting it on as long as you are on the herm, c or fan post. hope this helps.
Jun 23, 2011 | Heating & Cooling
I have a lennox G26Q3-75-2 furnace it ignites you can hear the pressure switch click to engage blower motor, but blower motor will not turn, its not froze up
Hello, most likely the capacitor has failed and needs to be replaced. the capacitor is a small oval or round can with either two or three prongs on it. When a capacitor goes bad the motor has trouble starting.
Feb 23, 2011 | Heating & Cooling
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
I need help wiring a Delta 28-280 model bandsaw from 220v to 110v. The saw came 110v from the factory, but the previous owner re-configured the wiring to 220v. I need it back to 110v. Thank you.
Rewiring the motor isn't hard, but be aware that you can hurt/kill yourself if you mess this up.
That said, manual is here.
Before you start, make sure you have a couple wire nuts (orange & yellow are a good sizes), a replacement plug, and some electrical tape.
1.) Unplug the cord from the wall. Go ahead and remove the prongs since you're going to need to switch it back to a 120V type prong adaptor. Don't put new prongs on until you've got things rewired. This will help keep you from accidentally electrocuting yourself.
2.) Open the saw base and have a look at the motor. There's a cover held on by a single screw. There should also be a wiring diagram on the motor that looks something like:1aa0c59.jpg
3.) When you remove the cover you should see three groups of wires. There should be numbers on the wires, but you can also figure them out by looking at the number of wires grouped together (see wiring diagram).
4.) You want to change from three groups of wires to two groups of wires per diagram, so when you're done, 1,3, & 5 should be grouped and 2,4, & 8 should be grouped. This is assuming your wiring diagram matches mine.
Make sure you don't have any exposed copper (cover w/ electrical tape if necessary). Make sure you have the wirenuts screwed on securely. Make sure you close the cover up and put the screw back in reasonably tight.
Put the prong on the wire, plug it in, and hit the start button. If you did everything right, it will start right up and no breakers will trip. If you goofed a pair, your motor may spin in the wrong direction. Otherwise, enjoy.
Jun 04, 2010 | Saws
Kenmore 90 series mod.# 110.28912791
OK The Kenmore 90 series mod.# 110.28912791 is not hard to work on. The problem on the washer was no agitation or spin.First I took the agitater out of the tub,and put them aside. Then I tilted the washer to get to the bottom of the washer. Inbetween the motor and I gueuss pump there are three pieces that need to be replaced called (motor coupler). I disconnected ac cord from wall outlet, the cold and hot water hoses. I disconnected the wires at the motor one piece and one two wire connection pluss move a small canister with two wires out of the way. Removed three bolts bottom of pump pulled pump and motor out, you have to turn back and forth a little and the whole assembly comes out. there are two screws that hold two clips at side of motor and motor come off easy. You will notice there is a black rubber disc with a plastic white three prong piece on each side. (Remove those pieces install same way ( you need to use something to hit the center of the plastic till it sets in, install black rubber piece six wholes three prongs on one side. Install second white pronged piece on the pump side and also hit center to set. Place pump over motor looking to (make sure) the top three prongs go inside three holes left in the black rubber piece. Once you line and they go inside line the motor to where the for rubber legs sat before put clips back on install the two screws, install shaft back in moving the motor side to side install the three bolts, hook wires plugs under the motor put canister with two wires back hook the two hoses back next to motor, stand washer back up, install agitater back, hook hot and cold hoses back plug back in and test. parts at sears (one hours time start to finish taking your time) keep track of all parts. Make diagram if you need to believe me it was easy and washer works great now. By the way when I took the parts off they did not look broken but were bad because now I have a working washing mashine. ( Good Luck, Wyatt Earp )
Feb 02, 2009 | Kenmore 23822 Top Load Washer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
