Question about Kenmore Dehumidifiers
Kenmore 15420. It will start and run for a few minutes and then powers off. Regardless of 3 speed fan setting or humidity level it will run for 2-8 minutes and then power off. FIX?
  • 184 Answers
SOURCE: Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Posted on Dec 19, 2007
SOURCE: humidifyer control panel,doesnt work.
power button does nor work
Posted on Jun 11, 2008
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Posted on Jun 14, 2009
bozcro
  • 867 Answers
SOURCE: kenmore 580.51650000 dehumidifier: compressor
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
Posted on Aug 21, 2009
milten1
  • 1304 Answers
SOURCE: Fan kicks on but compressor does'nt start
i would do a continutity check on you relay and overload, other than that
what is the humidity level in the room, as well as the ambiant temp. these mahines cycle for that very reason, the fan will come on, do a check and then determine if it should start the compressor.
check if you have voltage at the compressor when its supposed to be running ( just a last thought)
ive seen compressors ohm out, but in fact be bad
Posted on Oct 09, 2009
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
I have the a Kenmore dehumidifier sometimes it runs fine and other times just the fan runs not the compressor or just the opposite the compressor runs not the fan it is only 2 1/2 years old. What should...
Kathy, I'm not sure you have a problem with the dehumidifier. Depending on which mode you're operating it in, the fan will run in an effort to recirculate the air. If the humidity level rises above the level you have the unit set on, the compressor will then turn ON. This is particularly true, if the unit is operating in continual mode. Then there are other times the fan isn't active, but the compressor turns on when the humidity sensor feels a rise in humidity. So, for the most part, I don't think it's a problem.
Just be sure that you clean the air intake filter at least once every two weeks, during times of daily operation.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Kenmore 54351 Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
I have a kenmore dehumidifier (about 2 years old), and i've found that after i turn the unit on and it is running for 2-3 minutes, it will then shut down even though no water has collected in the tray. any...
My first thought is that there's not enough moisture/humidity in the air, for the setting you have the humidifier set on. The higher the setting or percentage (i.e. 60%) means that the level you want to maintain. Which may be find in the cod winter months. In the Hot summer months, you want as low a level of humidity as possible (i.e. 45%).
My second thought is that the air intake filter and the coolant coils need cleaning, since it has been used in 2 years. It's just sat around gathering dust and spiders.
And finally, the collection bucket, may not be inserted properly and when the unit starts up the vibration dislodges the bucket just enough, so that it's not making contact with the safety switch. Sometimes when this happens, the Full light indicator will come ON, even if the bucket is empty.
Hope this helps you to start troubleshooting the problem. Please let me know.
May 01, 2011 | Kenmore 54501 Dehumidifier
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
Fan kicks on but compressor does'nt start. Humidity control checked out. Compressor ohmed out. Fan runs for about a minute then it shuts down.
Oct 09, 2009 | Kenmore 54351 Dehumidifier
Jun 14, 2009 | Kenmore 54501 Dehumidifier
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
