Question about Hotpoint Washing Machines
Got a Hotpoint aqualtis aq113d697e door will not open all light flashing and error code f6 hope you can help me fix it
barkencoa
  • 3463 Answers
SOURCE: on a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Posted on Nov 20, 2008
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
Posted on Jun 28, 2010
SOURCE: trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Posted on Sep 22, 2010
  • 6277 Answers
Indesit (Hotpoint) 'F05' decodes as 'pump block'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
My hotpoint Aqualtis has an f6 code displaying.. Any ideas on what the problem is and how to fix please?
Hi!
F6 means:
- Broken buttons;
- A faulty electrician between the control board and the controller;
- Faulty electronic module
Mar 05, 2017 | Hotpoint Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
May 17, 2014 | Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
Jun 25, 2009 | Hotpoint Washing Machines
Hotpoint Aqualtis Stacking Kit
I Have the same machines and the only option is the Hotpoint stacking kit. Available from Hotpoint - 08448225225. They are selling it half price at the moment for around £70 delivered. I have been assured by Hotpoint this is the only option.
Mar 01, 2009 | Silver King Stacking Kit For SKR27 and...
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Aug 03, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
