Change bulb in twinstar elec fireplace - Heating & Cooling
2 Suggested Answers
SOURCE: twinstar electric fireplace - fireplace heat comes
I have the same problem. Heats fine for a 1 minute then 'click', and no more heat. If I turn it off and wait a few minutes, 'click' and it will blow heat again (for 1 minute...).
Link from Mike didn't help because this is an Electric heater, in an 'amish fireplace'.
I'm thinking it might be a faulty 'thermal fuse' or possibly the thermostat.
http://www.ehow.com/how-does_4969160_thermal-fuse-work.html
Posted on Sep 08, 2012
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
How do I change lightbulb in Prolectric fireplace?
How to Change the Bulbs in an Electric Stove Heating Unit ...
? 3:26
https://www.youtube.com/watch?v=wICIyjUhHfs
Apr 17, 2013 - Uploaded by doityourselfstan
Easily restore them with a pair of light bulbs and a screwdriver.... electric fireplace and it came with a extra bulb but didnt say how to change it.
Oct 29, 2015 | Heating & Cooling
How do change a bulb in a classicflame 23ef010gaa
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
Need twinstar circuit board model 28e05-r pt #pro-082a
Bad news company...5 year old $500.00 device and the control board failed. NO parts...offered to sell me a new insert..No way Jose
Jan 17, 2014 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace won't come on. We changed the light bulbs. Nothing will work. What do I check now
https://www.heatsurge.com/help/service-store-locator
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Dec 09, 2012 | Leisure HOMEPRIDE Electric Fireplace...
NEED AN ON OFF SWICH FOR A TWINSTAR ELECTRIC FIREPLACE HEATER SWITCH PART NUMKBER IS SR22N
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
Nov 12, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Elec. fireplace on switch
I found a website that has many of these parts. Try ibuyfireplaceparts.com.
Nov 02, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
