Question about Optoma Office Equipment & Supplies
Message, fan locked on optoma pro 160s projector and projector shuts down. Can anyone tell me what I can do. Now we can't even get the tv to come back on.
swami nathan
  • 208 Answers
SOURCE: Optoma EP716 Projector
Make sure that the resolution shown by the projector matches with that of the computer resolution. Many projectors does it automatically.
But if there exists a problem in resolution matching, there is a chance of getting partial picture. So better check that the resolution shown by the projector matches with that of the computer.
Also, the pixel may be degraded due to,
  • Their susceptibility to heat; the organic compounds used in LCD filters - in particular the blue - can be broken down by excess heat, resulting in a degradation of image quality.
  • "Dead Pixels"; pixels can become permanently on or permanently off, and while this is barely noticeable with one dead pixel, the presence of multiple dead pixels can be a irritation.
The only way to fix the problem is to replace the 3 LCD panels which, if you could get the part would cost you more than a new one.
LCDs are really difficult to make so lots of them do actually get passed with dead pixels on them.
But i suggest you to get some advice from the service center too.....
Hope my info solves your problem.
Thanx for using fixya.
Posted on Oct 01, 2008
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
SOURCE: Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Posted on May 25, 2009
  • 50 Answers
SOURCE: Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
Posted on May 28, 2009
SOURCE: Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Posted on Jun 06, 2009
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
New ML500 projector shows:
I had the same problem. I opened the case and found that an insect had died and stuck to one of the fans, preventing it from rotating freely. I scraped off the remains of the bug and it works again.
Sep 01, 2012 | Optoma Office Equipment & Supplies
Optoma hd20 fan shut down
I put this here because when I was experiencing the same issue I found there was very little info online for this topic. Optoma asked me $125 just to take a look at my out of warranty hd20 projector after I started getting the dreaded "fan failure" error message, I got this error mesage after replacing the bulb (its important to note that the bulb did explode in the unit so some of the debris may have lodged in the fan.) Optoma also kept saying stuff like motherboard issues and fan sensors on the phone. Everything I've read has said the repair price is so high on these issues that it is better to upgrade to a new projector so I resigned myself to doing that very thing. Then I ran up on this video and thought what the heck. So I took the plunge and popped the case off and sure enough the same little fan was stuck and covered with dust. I gently moved it with a screw driver and blew all the dust out of it. Plugged it back in and I'm experiencing glorious 135" hd once again.
Feb 28, 2012 | Optoma HD20 DLP Projector
Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Mar 26, 2010 | Optoma EP7155 Projector
Over heat and shut down
I had a similar problem with mine. I just put a fan on it, and that seemed to work...
It just needed more air flow and cooling...
May 14, 2009 | Optoma EP758 - HDTV Compatible DLP...
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Mar 01, 2009 | Optoma HD65 DLP Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Mar 09, 2008 | Cameras
82 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
