Question about Hitachi EC2510E 5.5hp Gas Air Compressor
Engine will run ok, But will not start with some
Engine will run ok, But will not start without some kind of fuild put direct into carb.
    Genius:
  • 1,071 Answers
There should be a primer on the side of engine near carb looks like a rubber bubble push 3-4 times should fix ya
Posted on Jul 21, 2009
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
1988 mustang 2.3 has spark,fuel will not start
What you should check is firing order, any motor that has spark and petrol must at least back fire, when try to start, if it is still not doing that I would do a compression test to make sure compression is ok, then check the carb to make sure there is fuel in it and that the flot level in carb is correct check clean the carb all the jets and places where petrol flows through the carb, once you have completely clean and checked the carb then you know it's not the carb then you go to the next thing. Spark, is the bogie cables work properly replace them if it is shorting out against the body of the engine, replace the condenser that is on the side of the rotor cap those things are known to give trouble, they work sometimes and then it stops working, anyway good luck hope this is of use to you.
Nov 03, 2012 | 1988 Ford Mustang
Changed carb engine running ok but no drive when i went to ride it please could you help me kind regards bri.the model is a gillera stalker 50cc
Check your carb if there is enouch deposit of gasoline , if non then you need to clean your carb or you might need to change your jet needle.
May 20, 2010 | Motorcycles
19 hp Murray garden tractor won't run
no sounds like your carb needs a real good babtising! good look!
May 19, 2010 | Briggs & Stratton Garden
Identifying the engine used in a Poulan PO16542 mower
I suggest removing the carb and taking it to an authorized B&S repair shop, they will be able to I.D. it.
Apr 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
6-5 vacuum will not start with out stating fuild
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Sears Vacuum Shredder Bagger Replacement...
Chainsaw Mcculloch 310 powermac not running
Change the air filter.. Try starting it without the air filter in.. See if it will run..
If it sat for a long time the fuel will shellac in the carb and cause it to not work the way it is supose to..
In these cases the carb would need to be cleaned and rebiult...
Good luck
Sep 24, 2009 | Garden
Car starts in the morning, but does not want to accelerate...
Check your cold start curcit in the fuel injection. It puts extra fuel in to help it run when cold ( used to be a choke on old carbs) then when you restart it the engine has warrmed enough to run without the cold strt curcit.
If you just start is and don't move it just let it run will it clear up and not die?
Sep 02, 2009 | 2003 Kia Spectra
Hitachi EC2510E 5.5hp Gas Air Compressor Logo
62 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
