Question about Hitachi Televison & Video
We bought a new Hitachi 43" TV and the speakers keep making the sound skip/jump? We've tried turning it off and on again but it hasn't helped
ctf1800
  • 4402 Answers
SOURCE: hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
SOURCE: HEADPHONE SPEAKER WIRING
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Posted on Jun 06, 2008
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
  • 927 Answers
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Posted on Sep 06, 2008
greg_margo
  • 1959 Answers
SOURCE: 2004 Dodge Neon Fuse problem?
Sounds like corroded battery terminals/cables. The battery should have held a charge after jump starting. When a car won't even jump start, it's a sign of a dead battery or corrosion on the posts or cables. Throroughly clean the posts and cables and try to jump start again. The error code should clear itself since the battery would be disconnected. If you are not able to jump start the car, post back and we'll diagnose further. My guess is cleaning the posts and cables will get you running again. Best of luck!
Greg
Posted on May 22, 2009
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Cd's skip
Hi have you got the speakers near the CD unit and if so is it on a secure shelf as my friend had the exact same problem ? It turned out that the Bass from the speakers were making his CD's skip
Hope this helps Nick
Jul 15, 2017 | Apex Digital AD-1125 DVD Player
Hitachi ultrascan HD tv 43 inch
Good Day;
Jul 11, 2008 | Hitachi 43UWX10B 43" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Apr 05, 2008 | Hitachi DZ-MV730A DVD Camcorder
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
My tv sucks help me
Ryan, this sounds as if the green CRT has gone out in this set. You might want to double check the warranty of your television as this set might have a lifetime warranty on the CRT's. If you cannot find the warranty info on your set, call 1-800-448-2244 for further assistance
Nov 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
(Hitachi 43F300) Turning its self off
Sounds like it is going into shutdown mode. When the TV power supply and system control sense an overload the system control turns the TV off to prevent further damage from happening. I suspect it is a shorted convergence IC. It would be best to call a service center to repair the TV.
May 18, 2007 | Hitachi 43F300 43" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
