How do you run a diagnostic on GWL 11 - Washing Machines
4 Suggested Answers
  • 3 Answers
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Posted on Oct 09, 2009
  • 713 Answers
SOURCE: GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Posted on Jun 23, 2010
  • 6 Answers
SOURCE: replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Posted on Nov 22, 2012
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL 11
50. (00110010) Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the hot valve is faulty. The most likely cause is that the valve harness has not
been connected correctly or the valve is open circuit. See fault 48 for service procedure.
48. (00110000) Hot and Cold Valve Coil Faulty
The Motor Controller module has measured voltages from the valve diagnostic circuit that
indicate both the hot and cold valves are faulty. The most likely cause is that the valve
harnesses have not been connected correctly or the valve is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves or the
pins are not bent backwards.
Secondary Source: Water Valves.
Action: Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action: Replace the Motor Controller module.
Feb 28, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Paykel Model GWL 11 washing machine. A couple of days ago the machine was operating, but when it came to the spin cycle it would not enter the cycle. It kept trying, but eventually let out...
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Jun 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
