Question about Windchaser PACR10000 Portable Air Conditioner
Led lights and beeps but does not turn on.
I have tried to turn on my portable air conditioner and the led lights work and the alarm light is on but it does not start up.
  • 54 Answers
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
  • 11 Answers
SOURCE: Windchaser air conditioner alarm light is on and it won't turn on
look at the water shut of float, as when the bottom of unit fills with water nor the bottom water float shut of gets stuck in the up position of the toggle relay itself get falty this will cause the proble you discribe
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
SOURCE: carrier holiday portable air conditioner manual
Mine has a model number of PCA061D.
If you remove the water capture reservoir, there is a sticker that has the model number.
Posted on Sep 29, 2010
Need a manual for a Windchime PAC9 Model SA 12059 Air Conditioner, or advise on how to bet alarm light to turn off so unit will work
on the WEB
Windchaser PACR9S Instructions Manual - ManualsLib
www.manualslib.com > ... > Air Conditioner > PACR9S
View and Download Windchaser PACR9S instructions manual online. WindChaserProducts Inc. Instruction and Maintence Manual Portable Air Conditioner ...
Aug 04, 2015 | Windchaser Heating & Cooling
How to stop my Frigidaire 15,100 BTU from beeping
Hello Naomi - Thank you for your question. When the air conditioner is beeping, it may be a warning sign that the filter needs to be clean or that you need to reset the unit. The LED (light) will illuminate and beep after 250 hours of operation. After cleaning the filter, you may reset the "FILTER RESET" option by simply pressing and holding down the button for approximately twenty seconds and the light/beeping will go off. However, if you have done this, try pressing the "RESET" button on the GFI plug of the unit. Wait approximately 2-3 minutes and then turn on the air conditioner. If issue persists, then at this point I would suggest reaching out to the manufacturer directly to see if you have any limited warranty on the appliance or you may alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Jun 14, 2013 | Frigidaire 15,100 BTU Heavy Duty Window...
My Delonghi portable air conditioner stops working all of a sudden and the alarm light comes on.
The alarm light glows when the water collection bucket(s) need to be emptied.
Jul 07, 2011 | Heating & Cooling
I have an Amana AP148DS POrtable air Conditioner. Is there a way to turn off the LED light?
No, unfortunately there is not a way to disable the light unless you are to disassemble the unit and remove the light.
Jun 10, 2011 | Amana Heating & Cooling
Alarm on on portable ac
If this is the kind I'm thinking of the condensate tank needs to be emptied of water.
Jun 02, 2009 | Royal Sovereign ARP-1008 Portable Air...
Red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Jan 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Jan 09, 2009 | Dometic Rooftop RV Air Conditioner
Wont turn on just keeps beeping
Hi, I posted the same problem. I unplugged the unit overnight, and now it works. don't know if this will help, but it works!!!! :D
Jul 04, 2008 | Sunpentown SF-610 Portable Air Conditioner
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Windchaser PACR10000 Portable Air Conditioner Logo
57 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
