Question about Kitchen Ranges
I have a Beaumark stove the oven will not come on I get an F14 error
The burners work but the oven doesn''t come on
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JES1290,
Not sure about an F14 error, but an F4 error is a shorted (or even just greasy) temperature sensor (thermistor). That could cause trouble with the convection and fan, etc. like you describe.
It looks like the thermistor on this model comes as part of the heater or one of the covers, etc.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find a very good exploded view of it at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00058700/00058754.p01.pdf
You can find parts here: http://www.geappliances.com/shop/prts/
Posted on Nov 18, 2007
  • 399 Answers
SOURCE: Old Beaumark electric kitchen range
HOW MICROWAVES WORK Microwave ovens are complex and sophisticated, but they operate on a very simple premise. They warm foods and liquids using microwave-frequency sound, rather than a gas burner or an electric heating element. How microwave energy is produced Why some foods cook better than others Safe, quick, and inexpensive How microwave energy is produced Your microwave oven has a small transmitting antenna, much like a radio station or TV station might use. The microwave oven converts the electricity from the house into an extremely high voltage, which feeds the "magnetron, " which converts the high voltage into radio waves. The radio waves funnel into the cooking area of the oven, which makes the molecules in the food or liquid resonate (vibrate) wildly?which causes friction between the vibrating molecules?which generates the heat for cooking. Why some foods cook better than others Whether a food type is suitable for cooking in a microwave oven has a lot to do with the structure of the food--or the lack of it: Consider bread. It has an internal structure of air pockets. When the microwave gets all of the molecules in the structure vibrating at microwave frequency, the structures break down and the bread becomes tough and inedible if cooked too long. Now consider water. It has no structure. When the microwave frequency gets the water molecules vibrating, they rub against each other creating friction--then heat. Because they have no fragile structures to break down, foods with high water content tend to heat nicely in the microwave--including vegetables, soups, and so on. Safe, quick, and inexpensive Because microwave ovens use radio waves, rather than radiant heat, to heat food, they are considered to be quite safe. Also, they don't introduce anything unnatural into the food, and they are more energy efficient than standard resistance cooking devices. Q - My microwave seems to shut off every once in a while, what might be wrong? A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt. Use an old tooth brush to help clean off the grille area. Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food? A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything. A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running. A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Q - My microwave went dead when I opened the door ( same problem as closed the door ). A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse. Q - My microwave is completely dead. A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. Q - The fan in my microwave oven is not running will this hurt my microwave? A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace. Q - My microwave blows the fuse inside itself as soon as I push the start button. A - Usually a shorted high voltage capacitor...see components section. A copy and tip from Prashanth: Description of problem (Maytag CMV1100Q) : Microwave stopped working while cooking. Replaced a 20AMP fuse. When the cook cycle starts, microwave makes a groaning noise and stops. It loses power since the fuse is blown. Solution: High-voltage capacitor shorted. Replaced it and microwave works fine. Its located behind the fan underneath the high-voltage transformer. Remove the vent fan hood Remove the display control panel by removing the screw Take pictures of all the connections behind the control panel. Unhook all connections Remove the connections to fan Remove the fan Remove the screws and connections for interlocking switches. Make sure the high voltage capacitor is discharged! Remove the high voltage capacitor and replace Retrace the steps and put everything back. Microwave works great now. Q - I burnt something in my microwave and now it is dead...help! A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that click on the link below for which u have the doubt http://www.applianceaid.com/micro.html
Posted on Sep 22, 2008
SOURCE: beaumark stove
The bottom element quit working and whats up with that!!!It is not burnt out we checked for that
Posted on Nov 13, 2008
ziraffa
  • 827 Answers
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Posted on Jan 11, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
