Question about Metabo Saws
Metabo grinder well 15 150 quick, rpm slow down after a few seconds of run time.
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Posted on Sep 12, 2009
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
  • 185 Answers
SOURCE: Dear Sir, We have few Metabo
Hello, a dead man switch functions in this manner. As long as you hold the switch down the grinder functions, and as you know when you release it the grinder stops. This is a good safety feature in that if you drop the grinder of lose control of it, if the grinder stays running it could cause a lot of damage to material or your body. The switch can seem to be a pain when having to hold it down all the time, but it is a safety feature that can actually save your life in the case of you losing control of the unit.
Posted on Mar 13, 2011
Metabo grinder 01119190 MFE30 speeds up then slows down continuously
probably needs new motor brushes and the commutator cleaned up
Jun 30, 2017 | Metabo Saws
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Dear Sir, We have few Metabo grinder I have some doubt about Dead man switch can you explain me what is the function of dead man switch. Regards Nitin
Mar 13, 2011 | Metabo W10 150Quick Angle Grinder W10 150...
I own a metabo 9-125 quick but can't don't know how to place the blade
On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Disc flies off when grinder stops
yes the above is correct with the question "are the threads the right size." but it can also be because u are not slowing the grinder down before stopping it. if the grinder stopps to soon the disk will stay moving. so the disk will fly off. i had the same problem with a pnuematic grinder. sometimes it is the operaters fault not the tools.
" an object in motion aloways stays stays in motion till an outside force dissrupts it."
Jan 10, 2009 | Metabo W6-115 606111420 4 1/2" Angle...
Saws Logo
126 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
