Question about Ovens
I have a classique oven, five functions. Problem is cannot turn the oven on, at any function, although power is on and clock is set to correct time.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Can you get me a model number for your oven and ill see what i can do.
Posted on Dec 21, 2016
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
Which of the five small buttons do I press to make the oven function? start
Ok! Until the clock is set the oven will not work, I will describe the 5 buttons as numbers from the left!
Press and hold the 3rd button for 2seconds, then press the 4th or 5th buttons to set the clock to the correct time, then press the 3rd button to set!
Jan 01, 2015 | Smeg Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Dont know how to turn off the auto seting
Turn off the mains power. wait about thirty secs. turn back on, you should have either all 0's or 8's flashing. Looking at the clock buttons left to right. press the button fourth from left and the - or + to set the time (doesn't have to be the correct time, just not flashing 0 or 8's). Leave for second until the display is not flashing.You should be able to use the oven now. If not you may have a problem with the clock, this can happen if you have been using the top grill with the door open and the controls have gotten too hot. Neff ovens have no function where the door is left open during cooking or grilling.
Mar 07, 2013 | Neff U1721 Double circotherm Electric Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
I have a classique gas/electric oven and need to set the clock because of power cut. Oven was in house when purchased so have no manual. Think this is model 2320 SS although not certain as plate with info...
Cassique gas top & electric oven. Oven does not have usual temperatures but has 1 to about 20. What do these numbers relate to in terms of temperature
Mar 05, 2009 | Ovens
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
171 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
