Question about SWANN Home Security
I have installed a Swann 754 camera it works fine on the control panel supplied but when connected to my Nightwatcher DVR system.
I can bring up the PTZ menu...but it will not let me access to set up any tour or other command?
SOURCE: GRRS Setting Using Reliance Smart
cant connect to internet
extra initialization command needed
MTKBTDEVICE (chinees mobile)
plz help
Posted on Aug 10, 2008
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
SOURCE: swann surveillance system at home
Try and take down the firewall. Then try remote access.
If that does not work . check the port forwarding settings on your router .
Posted on Jan 05, 2009
SOURCE: installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Posted on Jul 31, 2009
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
How do i connect swann cameras directly to tv
Ashley, I believe you can with a HDMI cable or VGA cable. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Video Instruction Guides
Home surveillance systems dvr camera system Swann
setting up swann
May 14, 2016 | SWANN Home Security
How do I get my Swann ADW-400 camera/recorder of of PAL mode and Back to NTSC
Connect the DVR to a monitor, go to system or camera settings, select NTSC as signal type, save and reboot the DVR.
Jan 12, 2014 | SWANN Adw-400 Video Surveillance System...
Picture was fine on all 4 cameras then it lost color and started rolling on the monitor .
You have the wrong settings on the DVR, go to DVR menu system or camera settings and change the setting from PAL to NTSC.
Jan 28, 2013 | SWANN 4-channel/camera Dvr Surveillance...
Hi! I have a DVR4 2600 Swann, my cameras are working, but I can't get into the menu either directly on the DVR controls or via the remote???? I...
depress and hold the rewind button (<<) on the remote (or on the panel)until the units beeps.
It may take 20-30 seconds. or you may have to do it severalk times before you hear the beep. Once the unit beeps you should be able to get to the menu using the remote or the faceplate button.
Please note that the remote is infrared so the sensor on the faceplate is sensitive to where the remote is relative to the sensor on the faceplate.
Jun 01, 2012 | Swann Communications DVR4-2600 4 Channel...
Swann Communications DVR-4-Net camera card won't run?
What spyware software did you run? Do you have the name of the software?
many spyware software available on the internet are actually viruses and malware.
Download the file combofix from the link below and run it on your system. This should remove all viruses and errors on your machine
Mar 11, 2009 | Swann Communications DVR-4-Net (SWRPCDVR4)...
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
Home Security Logo
44 people viewed this question
Top SWANN Home Security Experts
Todd Arndt
Todd Arndt
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
