I have a tech solutions handheld TS-750 calculator that's pretty old, and I'd like to replace the battery, if I could figure out where it goes. it says on the back that it takes an L1131
Need instructions for the MU, CST, SEL, MAR keys and what the arrow key is for above the MU key.
Just Google search (brand/model) user manual for instructions, as you don't indicate which calculator you have!
May 09, 2016 | Office Equipment & Supplies
Are there any cheats for My Life?
Nope. its a pretty old game from back in 2007, i looked so many times.
maybe if you get keys for the back of the handheld, you unlock clothes/ parts of the map.
May 26, 2012 | Playmates My Life Handheld
I have a stripped gear in my TS-6000. How do I order replacement parts?
The Tech Solutions shredders have been discontinued for years now. No parts are available. I called the 800 number and was told all parts were liqudated due to discontinuance of the shredders.
Jan 12, 2011 | Tech Solution TS-6000 Shredder
My handheld camera model does not seem to charge. I leave it on charge all day and it only has one bar of power when not plugged in?
ok,just figured it out,the plug that goes into the socket vertically is pretty much useless. As soon as you plug it into the handheld device to charge, it shuts off. I took the plug that goes into the socket horizontally and plugged it into the handheld and it began charging. So to use the product, you need to charge the handheld fully and then use the same plug to plug in the actual video camera that is pointed at baby,then you will be set to go. The company should send 2 horizontal plugs.
Dec 17, 2010 | Summer Infant Slim Secure Handheld Video...
Do you have a battery L1131 for the TS 450?
I don't, but you can order one from
Jan 30, 2010 | Tech Solution Office Equipment & Supplies
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
On/off button doesnt turn on
normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Aug 31, 2007 | Tech Solution TS-900 Calculator
On/off button does not work
The ac key is you power on key. As far as not being able to input any numbers, make sure there is not a key that is stuck down or depressed. if so try to lift is up and you should be ok. Unless there was a liquid spill. In that case, cheaper to buy a new one.
Jun 08, 2007 | Tech Solution TS-900 Calculator
Can't get numbers to display
Make sure there is not a key stuck in the depressed state. If so try to pull it back up and you should be set. If the machine had a liquid spill this could cause that type of error too. In which case the machine is junk.
Open Questions:
64 people viewed this question
