Question about Goodman Heating & Cooling
The is gas is going off and every 5 min. i put new thermostat. model # capf036a2a, brand name goodman
    Master:
  • 841 Answers
Check the thermostat set up ..some has to be switched either by set switch on back or through the initial set up program of gas furnances. It appears as though it is set on a short cycle by default. Follow the instructions to the T. Make sure you have the proper thermostat for your type unit. some are for gas, some are for heat pumps, some are for oil, others are switchable with settings.
Posted on Oct 04, 2017
2 Suggested Answers
  • 22 Answers
SOURCE: Goodman Model # GPG15709041AA Gas pack just
depending on the brand and if he had to recharge and pulled oil oiut of compressor it can cause comp to be load. goodman is also a lower end unit and you pay for what you get. it is a very reliable unit howvere
Posted on Aug 17, 2009
Where is the air filter for a Goodman # CAPF036A2A
If this is a case coil, they do not have a filter area, the filter is normally either installed in the return air grill or needs some type of filter installed just upstream if in a down air installation in a closet. If it attached to a furnace, there is a space provided by most manufactures for a filter installed just before the air return. If the furnace is in the attic or in a crawlspace, I never install a filter in these areas, but put a return filter grill in the return path.
Hope this helps
Feb 10, 2015 | Goodman Heating & Cooling
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
I have 2002 ram 2500 gas. starts easy runs well then just dies. will restart in 2 to 5 min. new fuel pump, new gas filter, new plugs and wires, new thermostat (195), new air filter.
Check again piece by piece all that you just replaced to make sure one of then is not faulty from that house.
Check the oxygen sensors
The engine PCM
Catalytic convertor
Wish you luck
Dec 20, 2013 | 1999 Dodge Ram
Put on a new thermostat.......added a 5 wire to the system and does not work now
dont understand what you are trying to say. What is name and model of unit. what is name and model of the thermostat. do you have straight ac with gas heat, straight ac with electric heat, heat pump, heat pump with back up heat and what kind, electric or gas?
Jul 07, 2011 | Heating & Cooling
Aug 17, 2009 | Goodman CKL60AR60 Air Conditioner
New Goodman condenser unit run almost contiously using too much e
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
Jun 11, 2009 | Goodman Heating & Cooling
Older model Goodman gas package unit
It sounds like it is still receiving a "call" for heat from the thermostat. First check that the thermostat is set for gas heat and not electric.(There may be a jumper or dip switch on the back). Read the directions with the thermostat.
Secondly, Verify that the wiring at the thermostat is correct. (R- to red, W to white, G to green etc.)
Third, If the first two do not fix the problem, then there is definitely a problem in the thermostat wire between the furnace and the thermostat. (usually the "R" and "W" wires will be crossed or shorted to the sheet metal around the furnace. You may just have to replace the entire wire. Best of luck!
Jan 28, 2009 | Goodman GMS90703BXA Heater
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
