Power supply for JBL Creature speakers
Need to know the voltage
SOURCE: JBL Creature 2 Blowing Fuse
I think you made a mistake with your fuse.
With my JBL i can see 9,5A 41FU.
Posted on Sep 08, 2008
  • 298 Answers
SOURCE: Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Posted on Mar 26, 2009
  • 7 Answers
SOURCE: JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Posted on Jun 09, 2009
SOURCE: JBL Creature Speakers
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
Posted on Jan 06, 2010
SOURCE: Just wondering what the power supply output JBL Media 3 Speakers
I have JBL Media 3 Speakers running on the factory supplied power supply and the label states: JBL POWER SUPPLY, Model No. DV-9319B, Input: 120VAC 60Hz 35W, Output: 13.8VDC 1.7A, UL Listed3T58, E148325, CSA LR99152, Power Connection Diagram shows, Ring: Negative, Tip: Positive, CAUTION: INDOOR USE ONLY
PERSONAL NOTE: The power supply DOES NOT have the AC plug on the back. It is big hefty black block with an attached AC cord on one side and an attached DC cord on the other. My speakers are mounted high on the wall and run at approx.90% of full volume with Bass & Treble set flat. Actual volume and EQ settings are controlled via the sound card software based "Mixer Panel".
Posted on Apr 15, 2010
I need to know the color code or the resistor's value for r134 on the Creature's pcb. If anybody knows, please respond.
Hi I done a search on Google and found a schematic it might help. Type in. Harman kardon jbl creature schematic photo :::: I done this search on my phone ...good luck
Jul 13, 2016 | Harmon Kardon Jbl Creature 3-piece Powered...
How many input voltage do i need for my jbl creature it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
You can purchase the power cord from eBay if you are in the US:
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Power supply
Went to radio shack and they had an adaptor
Nov 10, 2008 | JBL CREATURE II Computer Speakers
Fixing power supply
Hello, sorry for late reply. See last post:
"The power supply casing needs to be prised apart with a flat bladed screwdriver or similar. Takes a bit of doing - might even need a bit of of a hammer."
You have to slightly damage the casing to prise the two halves apart and it won't go back together properly - needs must!
In any case, replacing the fuse doesn't solve the problem as they keep blowing. There is a fault somewhere causing this to happen and that's where I'm stuck.
Anyone else??
Jun 18, 2008 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
Power supply
there is an internal fuse in the power supply adapter but you have to cut the box open to get to it.did this myself replaced the fuse and it now works fine
Dec 06, 2007 | JBL CREATURE II Computer Speakers
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
47 people viewed this question
