Question about Samsung Televison & Video
How can I get to the alpha letter to enter a passcode for my wireless home using Samsung remote AH59-02144S
4 Suggested Answers
PyroPCMan
  • 405 Answers
SOURCE: PASSCODE HOW DO I RESET THE PASSCODE?
You cannot reset the passcode, however the default passcode is "0000"
Posted on Feb 19, 2009
sharcnet
  • 2130 Answers
SOURCE: WHEN ENTERING ADDRESS - ALPHA KEYBOARD IS CORRUPT
Try recalibrating the screen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1236709210
- Jim
Posted on Jan 14, 2010
mikeywaf
  • 346 Answers
SOURCE: I can't use the WIFI
Greetings Reem - There are two likely problems keeping your Pocket PC from connecting to either your home or work WiFi networks.
The first is that your A716 is probably still running Windows Mobile 2003 or has been upgraded to Windows Mobile 5 -- Neither of which is capable of supporting the WPA security standard that is most likely setup on your work network and probably also on your home WiFi router. The easiest thing to do at work is to ask the person in charge of the network what kind of security is used on the network. Same goes for home -- Ask the person who setup the WiFi connection.
If the answer is WPA or anything other than WEP ( or open - meaning no security -- very, very improbable) you won't be able to connect your PDA to that network at all. At home maybe you have a chance to have the security settings lowered to WEP (of course your A716 will also have to be setup to use WEP).
The other possible problem you might be having with connecting is that your device has 802.11b WiFi built in (11 Mbps) instead of the now standard 802.11g (54 Mbps). Some networks are setup only to allow 802.11g connections. Again, you would ask at work and home. Here, if that is the problem, you have a chance of the settings being changed to allow 802.11b connections.
Thanks for using Fix Ya and good luck
Mikeywaf
Posted on Mar 14, 2011
Trying to set up a d-link DIR-601 where do i find the pin
Are you pertaining to your network key?These are the steps for you to modify the passcodes fields via router settings.
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | D-Link D Link Dir 601 Wireless N Home...
Linskys passcode changer on router
Dec 28, 2011 | Computers & Internet
Need to reset network passcode
Dec 28, 2011 | Belkin F5D7234-4 Router
IM HAVING PROBLEM SETTING UP WIRELESS ROUTER TO MY COMPUTER
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you can remove the network cable from the back of your pc.10. restart your pc then search for new wireless networks then connect.11. now enter the WPA passcode or WEP passcode that you have created on the instruction #8. then you are good to go.
Dec 26, 2011 | Zoom 45010003F Wireless N Desktop Router...
I lost my passcode for my d-link DIR-601 router can i get my passcode ?
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 or 10.1.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option, here you can check what is your router passcode or if you want to change it to anew one you can chage it as well8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Dec 25, 2011 | D-Link Computers & Internet
I am trying to connect a wireless ready Samsung blueray player to my Motorola Surfboad and it says to press the wps button on the surfboad, where is it?
NOTE: [] & "button(s)" represent features on the remote controller. {} & "key(s)" represent features in on-screen menus.
ROUTER INFO: WPS is on the SBG901.
BLU-RAY DISK PLAYER: You did not mention the model # of the Samsung Blu-ray disc player, so this information is somewhat generalized.
PREREQUISITE: Once you have attached Samsung's proprietary wireless adapter to that Blu-ray player, have connected that Blu-ray player to your TV, & have powered on that router & Blu-ray player & TV, access that Blu-ray player's initial settings menu.
STEP ONE: From the Home menu, press ?? buttons to select "Settings." Press [ENTER].
STEP TWO: Press ?? buttons to select "Network." Press [ENTER].
STEP THREE: Press ?? buttons to select "Network Settings." Press [ENTER].
STEP FOUR: Press ?? buttons to select "Network Type." Press [ENTER].
STEP FIVE: Instead of using the the "PBC (WPS)" selection, press ?? buttons to choose the "Wireless" selection & press [ENTER].
STEP SIX: Press ?? buttons to select "Internet Protocol Setup." Press [ENTER].
STEP SEVEN: Press ?? buttons to select "Auto" or "Manual." Press [ENTER].
IF SETTING UP WIRELESS CONNECTIVITY VIA AUTO NETWORK SEARCH: If you selected "Auto," press the ? button to go to "Access Point Selection." Press [ENTER]. Upon searching for available wireless networks, it will display those choices in a list.
A.) In the list of networks, press ?? buttons to select your network. Press [ENTER].
B.) IF "PIN/Security" DOES NOT POP UP, THEN SKIP THIS STEP; otherwise, press ?? buttons to select PIN or Security (Security Key--the usual option), & enter your network's Pass Phrase on the Security screen. (This Pass Phrase would be what you would use to access the network. IT SHOULD NOT THE PASSWORD WITH WHICH YOU SET UP YOUR ROUTER!)
Press number buttons on the remote to enter Pass Phrase numbers OR use arrow buttons on the remote to move from key to key in the Security Key screen. Change the type of on-screen accessible characters by moving to the on-screen {a/A/1/?} key & pressing [ENTER] on the remote. (The character set changes with each press of [ENTER]. Once displayed on the screen, you can enter a letter by pressing the number button on the remote which corresponds to that letter key. Pressing that button repeatedly changes the letter. You can move to {Delete} & press [ENTER] in order to remove the last character entered. You can move to {Clear} & press [ENTER] to clear all entered characters (or just press the red [(A)] button. When done, press the yellow [(C)} button (or the {Done} key followed by [ENTER]).
C.) WAIT UNTIL THE CONNECTION CONFIRMATION MESSAGE DISPLAYS & THEN PRESS [ENTER]. You're back at the Network Selection menu.
D.) To test the connection, press ? to select "Network Test." Press [ENTER].
IF YOU REQUIRE ASSISTANCE WITH SETTING UP THE WIRELESS NETWORK CONNECTION MANUALLY, I SUGGEST THAT YOU READ THE MANUAL (http://www.samsung.com/us/support/).
Jan 08, 2011 | Arris SURFboard SBG900 Wireless Router...
The power is not coming on, and when it does it says LOCKED, I don't have the original remote but I am using an RCA universal remote. How can I get my power back on??
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode.This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested.This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.Press HOME to exit the menu.
Jan 05, 2011 | Hitachi 51G500 51" Rear Projection...
Neded passcode for a kenwood cd-receiver
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 27, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Jul 17, 2008 | Samsung WEP170 Wireless Headset
Televison & Video Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
